Went To Auto Repair Shop And Got A Repair Estimate, Can't Decide If I Should Do It.
Old Nov 14, 2006 | 04:05 PM
Import_spoon's Avatar
Default Went To Auto Repair Shop And Got A Repair Estimate, Can't Decide If I Should Do It.
I went to a repair shop for my 1995 Acura Integra and i got an estimate. I don't know if i should get the oem parts or aftermarket and install it myself? If i go oem there going to be aftermarket in a while anyways. The repairs that would need to be fix is the Right upper control arm+Ball joint, Right outer tie rod, Left Lower ball joint, then alignment. The total of that + Labor is $393.78. I want to get aftermarket parts and do it myself. Is it possible for me to do it myself? What are some websites that will lead me to the parts that i need for my car? I'm new to Acura's so i don't really know but i know the basic things about them. Let me know thanks. Comments will be thanks!
Old Nov 14, 2006 | 04:31 PM
lilcoozzie's Avatar
Default Re: Went To Auto Repair Shop And Got A Repair Estimate, Can't Decide If I Should Do It. (Import_spoo
ok so let me just go ahead and tell you that when you get into stuff like suspension and doing it yourself its a total bitch and takes so much more time then just letting someone else do it and if you end up doing it yourself to save money you might run into a problem and have to end up getting into more cash and more time plus being pissed off ......or you can just take it somewhere let them do it if they screw your stuff up blame them and raise hell with them...plus its easier when you can just sit back and let someone else do all the hard work....take it to a professional even if its something small like suspension...trust me
Old Nov 14, 2006 | 04:39 PM
atg1290's Avatar
Im gonna disagree with lilcoozie unless your an impatient and unitelligent person. Go aftermarket now and dont worry about doing this all over again. Now with upper ca they have the bj already so you just need that and adustable ones for easy camber adjustment. Tie rods are an easy fix but just go to advance auto or something local(i would just do both will your at it its only 25$ more) and as for lower bj they are a bitch. The tool you rent from advanced sucked in my opionion but you can try. I just used a bfh and whacked the sob!
Old Nov 14, 2006 | 04:56 PM
be18see1's Avatar
Default Re: (atg1290)
suspension isnt too hard as long as you pay attention to what youre doing. ive pulled all the components off before myself. i even figured out how to do an alignment myself-all you need is a tape measure and a wrench.
Old Nov 14, 2006 | 05:09 PM
yeah i just looked at some aftermarket parts like coil overs, adjustable control arms, and thats it. What are tie rods? Are those the sway bars?
Old Nov 14, 2006 | 05:10 PM
Default Re: (be18see1)
yeah i think this repair is going to be easy but then what if you do something wrong? Its better to pay now then repair for alot more later. My dad learned that the hard way with transmission fluid lol!!
Old Nov 15, 2006 | 03:21 AM
TTT
Old Nov 15, 2006 | 09:15 AM
be18see1's Avatar
Default Re: (Import_spoon)
dont pull out the axles and transmission wont be a problem. coilovers are easy to install, but make sure you dont take off the top hat and kill yourself. find someone who knows wat theyre doing and have them help you. just look for diy jobs on google or on the stickies here.
Old Nov 15, 2006 | 10:50 AM
Sumslapper's Avatar
Year 3030
left lower ball joint needs to be pressed in by a shop.
Old Nov 15, 2006 | 01:28 PM
Default Re: (sumslapper)
thanks. I knew that might be a shop involved.
Old Nov 15, 2006 | 01:46 PM
Can someone lead me to a place where they have the parts i need for sale. Thanks
Old Nov 15, 2006 | 04:48 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">Can someone lead me to a place where they have the parts i need for sale. Thanks</TD></TR></TABLE>
Check out the sponsor section. Just scroll down on the main page.
Ali
Old Nov 15, 2006 | 05:33 PM
Default Re: (PrinceAli132)
Thanks for the info helped alot.
Old Nov 15, 2006 | 05:34 PM
Is the Tie Rod the sway bars or what are those? do they have aftermarket ones? sorry i'm new to Acura and Hondas.
BiG ChOr!Zo
Suspension & Brakes
13
Aug 15, 2009 02:43 PM
KrenzyRyan
Feb 20, 2008 11:00 AM
Keebler
Mar 13, 2005 09:37 PM
2ndgentegracer
Aug 30, 2004 02:31 PM
