Question turbo Hole????
Old Nov 14, 2006 | 03:13 PM
Low ofset turtle's Avatar
Default Question turbo Hole????
Sorry i dont relly knoe alot about turbo im just wondering!!what this two hole on my TURBO,This is firts turbo setup.. Thanks
Old Nov 14, 2006 | 03:15 PM
EJ1 wilcox's Avatar
Default Re: Question turbo Hole???? (crvtech eg6)
It's a water jacket. You can run coolant lines to and from the center section to help cool the turbo.
You don't need to hook them up, but it's not that hard to do, and it's some added insurance.
Old Nov 14, 2006 | 03:38 PM
Default Re: Question turbo Hole???? (EJ1 wilcox)
soo i dont relly need to put coolant line in to their ?And can i just block it off ?
Old Nov 14, 2006 | 03:46 PM
EX-T's Avatar
You don't even have to block it off.
Old Nov 14, 2006 | 03:50 PM
b20turboic's Avatar
Default Re: Question turbo Hole???? (EX-T)
Yeah you dont have to block it off ...
I have actually heard from a few people that when pushing your turbo to make its upper limits of power the coolent will actually cause enough friction to loose a few whp over not using it. Now if its true or not I dunno , I dont run it ...
Old Nov 14, 2006 | 03:52 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Question turbo Hole???? (b20turboic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic &raquo;</TD></TR><TR><TD CLASS="quote">Yeah you dont have to block it off ...
I have actually heard from a few people that when pushing your turbo to make its upper limits of power the coolent will actually cause enough friction to loose a few whp over not using it. Now if its true or not I dunno , I dont run it ...</TD></TR></TABLE>
i don't understand where friction could be as all it does is cool the housing and not touch any actual moving parts... if you can use coolant on a turbo USE it
Old Nov 14, 2006 | 03:54 PM
EX-T's Avatar
Default Re: Question turbo Hole???? (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">
Valid point and using coolant prolongs the life of a turbo without timing it. You can shut it off right after running it hard and it does very little damage to the turbo. That's why factory turbocharged vehicle's turbos are water cooled. It's all up to you.
Old Nov 14, 2006 | 03:55 PM
Thanks for all the Info
Old Nov 14, 2006 | 11:18 PM
esedulerp5tenin's Avatar
i'm j/w how you would go about hooking coolant lines up to it, cuz i dont see any holes or anything to bolt a flange to or anything
...unless its internally threaded
Old Nov 14, 2006 | 11:45 PM
EK k kay's Avatar
Default Re: Question turbo Hole???? (esedulerp5tenin)
It's internally threaded. You use banjo fittings.
Old Nov 15, 2006 | 07:23 AM
EJ1 wilcox's Avatar
Default Re: Question turbo Hole???? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">It's internally threaded. You use banjo fittings.</TD></TR></TABLE>
If you can find them.
I had a really hard time finding banjo fittings for my old water cooled turbo. I ended up buying some brass barb fittings from homedepot, they actually worked really well and never leaked.
P.S. I did buy the banjo fittings from ATP ($$$$) but they didn't fit my turbo so I had to resell them.
Cheap brass fittings FTW!
Old Nov 15, 2006 | 08:23 AM
b18sihatch's Avatar
adding the coolant line would be smart as its added cooling
with water cooled turbos a turbo timer isnt needed
with oil cooled turbos turbo timers also arent needed given thee motor is ran a short period of time to cool the turbo down
Old Nov 15, 2006 | 08:28 AM
pheurton-skeurto's Avatar
Default Re: Question turbo Hole???? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">with oil cooled turbos turbo timers also arent needed given thee motor is ran a short period of time to cool the turbo down</TD></TR></TABLE>
...that's what a turbo timer does.
Old Nov 15, 2006 | 08:37 AM
b18sihatch's Avatar
Default Re: Question turbo Hole???? (pheurton-skeurto)
exactly...
Old Nov 15, 2006 | 08:38 AM
BoostedEG6's Avatar
Turbo timers are a waste of money and a unnecessary need to hack your harness up...... I don’t know of many people that will run there motor and boost for a long amount of time and then turn it off right away.... most people will drive under no boost for a few mins before they shut the motor off.....
To the OP if you have the money I recommend hooking the lines up for the coolant
Old Nov 15, 2006 | 11:26 AM
Default Re: Question turbo Hole???? (BoostedEG6)
where do you tap into the coolant??
the t-stat?
sasinorm01
Oct 31, 2007 10:42 PM
SVPCEO
Feb 27, 2006 06:16 AM
1QwIkEf
Jan 29, 2006 07:47 PM
You_Get_Vapors
May 4, 2003 06:17 PM
