Lowered 91 EF Civic HB, Problem.
Old Nov 14, 2006 | 01:09 PM
rival12's Avatar
Default Lowered 91 EF Civic HB, Problem.
My 1991 EF Civic Hatch is lowered on Bilstein Shocks and neuspeed race springs, i recently put a new upper ball joint on the driver side front. and now the upper control arm bangs against the frame when ever i go over a bump etc...
How do i make it stop slamming against the frame??
it does have a front camber kit, and my winter wheels are on for now...
Old Nov 14, 2006 | 02:48 PM
24TEN's Avatar
PHANTOM MENACE
mine are grinded down to clear the frame.
Old Nov 14, 2006 | 03:38 PM
janz3n's Avatar
Default Re: (24TEN)
iv seen apicture of part of the shock tower cut out so they can clear.. but i think that was for air ride or soemthing.
Old Nov 14, 2006 | 06:28 PM
90_civic_Si's Avatar
Default Re: (janz3n)
It`s the camber kit that makes it hit. It sucks cause to not wear your tires out you have to put up with this.
You can trim the edge on the upper ball joint to clear the frame, that`s really the only thing you can do.
Old Nov 14, 2006 | 08:43 PM
jdm_ef9_b16's Avatar
what kind of camber kit did you use? ive seen some upper balljoint camber kits off ebay installed and they hit. they were a shitty cheap design.
Old Nov 21, 2006 | 01:43 AM
rival12's Avatar
Default Re: (jdm_ef9_b16)
its an ingalls camber kit, i just replaced to upper ball joint, and it only hits on the one side... maybe i should trim it down?? i bought it like this, so maybe it needs trimming....anyone??
it never had these problems before, and i only assume the guy before me would have trimmed it, cuz only the new one hits.
Modified by rival12 at 2:22 PM 11/21/2006
Old Nov 25, 2006 | 08:17 PM
garageEF's Avatar
Default Re: (rival12)
get that euro **** off there! your pissing off your car.
Old Dec 2, 2006 | 01:22 AM
rival12's Avatar
Default Re: (garageEF)
that civic takes to the german engineering quite nicely, and that would make sense, because Japanese cars were built off of the german models, just more refined, and smaller....
DC2ALLMOTOR
Nov 16, 2007 04:15 PM
firebane
Suspension & Brakes
Apr 18, 2007 10:55 AM
I Have an STD
Suspension & Brakes
Apr 9, 2006 05:24 PM
hondatuner20
32
Jan 26, 2006 07:44 AM
