bouncy clutch engagement
Old Nov 14, 2006 | 12:50 PM
typhoon's Avatar
Default bouncy clutch engagement
Hey all,
I have an ACT street disk, H.D. pressure plate, ACT flywheel.
I had these put in about 3 months ago, to replace my OE clutch.
I was told by the dealer the problem I used to have on my OE of "bouncy engagement in 2nd gear" was a result of the springs in the disk wearing out. So I thought replaceing with ACT would solve the issue.
It did. But today I got that same nasty bouncy engagement. I don't think I fried the disk already.
What else could this be? motor mounts? (I noticed it didn't happen when shifting in a turn, more noticable when going straight.
Oil leaking onto the disk?
Old Nov 15, 2006 | 09:13 AM
Slamaccord's Avatar
Default Re: bouncy clutch engagement (typhoon)
Check your motor mounts.
Performance clutches sometimes require a higher rpm engagement do to the stage of
performance. Performance clutches engage harder than oem causing decrease in rpm which may be causing your chatter.
Benny Honda
Transmission & Drivetrain
11
Apr 1, 2019 04:40 AM
accord99power
Aug 4, 2008 06:54 AM
2k1 SSM GSR
Jul 9, 2004 01:46 PM
INTEG_RON
Sep 11, 2003 04:15 PM
4thgenturboSi
Feb 16, 2002 05:42 AM
