250ish mpg is that right ?
Old Nov 14, 2006 | 10:35 AM
john666's Avatar
Default 250ish on a full tank is that right ?
auto 97 lude im getting around 250 miles for a full tank.. my sister with a 01 lude says i should be getting 350-400.. am i smoking crack or should my car be doing better ? i drive like a grandma in this car but the gas is making me poor compared to driving my civic.
Old Nov 14, 2006 | 10:42 AM
darkspector2.0's Avatar
you use 91~ octane right? civic is naturally gonna have better gas mileage and it uses cheaper gas.
Old Nov 14, 2006 | 10:52 AM
john666's Avatar
Default Re: (darkspector2.0)
yes i use 91.. im wondering could it be something like a bad o2 sensor or something.. i just changed the air filter.. the lude is bone stock im just wondering am i trippen or what
no cels also
Old Nov 14, 2006 | 10:58 AM
DOHCVTEC190's Avatar
if you could...calculate your MPG next time. if you don't know how to do that...
1. next time you fill up, reset your tripometer.
2. when it's time to fill up again, see how much gas you put in.
3. take miles logged by tripometer divided by gallons of gas put in
this will be a better indicator of whether or not you're getting the correct mileage or not.
250 miles sounds a little low if you're going all the way to Empty. I average about 320-330 miles before my light comes on or 25mpg in my 93 vtec.
Old Nov 14, 2006 | 11:14 AM
AndyD's Avatar
Default Re: 250ish on a full tank is that right ? (john666)
My H23 and H22 get the same mileage.....~385-395 per tank.
Old Nov 14, 2006 | 11:24 AM
E-Money's Avatar
crack FTW
Old Nov 14, 2006 | 11:27 AM
integra15's Avatar
Default Re: 250ish on a full tank is that right ? (E-Money)
250 sucks, you sould get 300 minimum and that would be all city driving.
Old Nov 14, 2006 | 11:37 AM
nafreak's Avatar
Default Re: 250ish on a full tank is that right ? (integra15)
I too am only getting 240 to the tank with mostly city driving that is also grandma like in my 97 base. That averaged out to 19 MPG last time I filled up.
not good. not good at all....
Old Nov 14, 2006 | 11:51 AM
WhiteBB2's Avatar
Default Re: 250ish on a full tank is that right ? (nafreak)
mine is sh!tty as well. I Think I average about 260 with interstate driving and city.
Old Nov 14, 2006 | 11:56 AM
snowblind7x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">auto 97 lude im getting around 250 miles for a full tank.. my sister with a 01 lude says i should be getting 350-400.. am i smoking crack or should my car be doing better ? i drive like a grandma in this car but the gas is making me poor compared to driving my civic.</TD></TR></TABLE>
you should probly just try to change the basic stuff that would help your mpg i.e. fuel filter, spark plugs, O2 sensor. You said you have a new air filter so thats good. Dirty/old oil can cause bad mpg as well.
Old Nov 14, 2006 | 12:08 PM
preludedriva's Avatar
400 on my h22 :D
Old Nov 14, 2006 | 12:31 PM
plikit's Avatar
Default Re: (preludedriva)
yeah i get just over 300 usually.
seems like i get worse mileage in the winter.. weird.. i know.
i just changed my spark plugs and air filter. fuel filter is next.. i have a feeling my cat is getting clogged.
AND cylinder 4 is burning oil... that plug was oil fouled. so im assuming the rings are bad.
Old Nov 14, 2006 | 01:01 PM
smo0th's Avatar
i get usually get around 290-320 miles (city/highway with vtec every once in awhile) before my light come on. I most I have ever done is around 360 miles and when I went to fill up I still had just under two gallons left.
Old Nov 14, 2006 | 01:06 PM
john666's Avatar
Default Re: 250ish on a full tank is that right ? (snowblind7x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">
you should probly just try to change the basic stuff that would help your mpg i.e. fuel filter, spark plugs, O2 sensor. You said you have a new air filter so thats good. Dirty/old oil can cause bad mpg as well.</TD></TR></TABLE>
just bought the car recently and im poor so im working at it.. wouldnt a clogged fuel filter slow down the use of gas not causing me to use so much fuel.
Old Nov 14, 2006 | 01:10 PM
asdfsad's Avatar
try using a different brand of gas. I used arco before and i got like 230 a tank. Switched to shell now and im getting well over that per tank.
Old Nov 14, 2006 | 10:22 PM
john666's Avatar
could the 02 sensor or any other sensor be bad without a check engine light ?
Old Nov 15, 2006 | 04:08 AM
PirateMcFred's Avatar
Don't drive during rush hour. Don't drive 100 mph. Don't drive on flat, low, really wide or sticky tires. Stay with an all weather 205/55/15 or a 185 if you want mileage. Don't whack the throttle open, use as much part throttle as possible. Advance your ignition timing a little bit via the distributor.
You could swap/replace the O2 sensor or see if the cat is clogged if you are really concerned about it. But most mileage issues are from driving style than from poorly maintained cars. There are days I get 130 miles to the tank and others I get up to 470 in my nonVTEC.
Pirate
Old Nov 15, 2006 | 09:29 AM
godslayer's Avatar
For city driving only, I usually get about 320 miles out of the tank before the low fuel light kicks in. On longer trips I's gotten closer to 400 miles before tripping the light.
Old Nov 15, 2006 | 09:33 AM
pprowler6's Avatar
Default Re: 250ish on a full tank is that right ? (PirateMcFred)
i usually get around 300 miles per tank or just under 21mpg
Old Nov 15, 2006 | 09:47 AM
zapa47's Avatar
Tire alignment is important as well.
dont forget about weight as well ( junk / tools / amps etc in the trunk)
I find it fun to drive frugally. The three main things to frugal driving are:
1: steady speeds, obviously not too fast.
2: moderate acceleration (not fun but it works )
3: brake gently or not at all If you can. conserve momentum coming up to a light by braking lightly you save gas because you dont have to build up momentum from a stop.
Old Nov 15, 2006 | 10:21 AM
Regal's Avatar
Ladies and gentlemen we are floating in space...
Default Re: 250ish on a full tank is that right ? (zapa47)
You guys should just calculate your actual MPG the way the guy further up in the thread said. I do this every tank. You can't really go by "miles per tank" because sometimes the gas light comes on early or late.
In my car, the light comes on at 280 miles. If I were getting 280 miles per tank, my mileage would be shitty. If I calculate my mpg, I generally get 30 or 31, which is a lot more than 280 miles per tank.
Old Nov 15, 2006 | 10:43 AM
Default Re: 250ish on a full tank is that right ? (Regal)
you mean like this?
Price of gas vs. mileage
Gee where were those track days?
Pirate
Old Nov 15, 2006 | 02:50 PM
Jagan'92's Avatar
lately my car's been busting out 400 miles per tank (30 mpg) every time. 93 octane fill up at the first low gas light (13-14 gallons)
Old Nov 15, 2006 | 03:49 PM
GraphiteMW's Avatar
Damn, I think I need to do a fuel filter change to see if thats holding me back.
Old Nov 15, 2006 | 04:57 PM
Mik3's Avatar
Default Re: (GraphiteMW)
Wow, i drive like a dumbass (vtec) everyday and still get ~330 all city. I think i could do better though if i drove better.
