Honda S2000 Honda S2000
Aftermarket seats?
Old Nov 14, 2006 | 09:43 AM
gfhb4s2000's Avatar
Default Aftermarket seats?
Anyone out there that is using aftermarket seats in there car what are you opions on them. I am looking to buy a set. Any fitment problems?
Old Nov 14, 2006 | 09:45 AM
LAS2K's Avatar
Default Re: Aftermarket seats? (gfhb4s2000)
there is a somewhat limited choice for seats...nothing too wide. i don't have one but i have sat in a few...the recaro pole position really hugs your thighs and gives great lumbar support.
Mr. Projekt's Avatar
* B A N N E D *
Only certain ones will fit. Most hit either the door or the glove box.
Bride buckets
Recaro buckets (SPG and PP)
Old Nov 14, 2006 | 09:49 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gfhb4s2000 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone out there that is using aftermarket seats in there car what are you opions on them. I am looking to buy a set. Any fitment problems?</TD></TR></TABLE>
keep in mind when switching to a racing bucket, make sure you're running the stock 3 point belt system. If not, make sure you have a rear aftermarket roll bar with a harness bar if you plan on running racing harnesses. If you're running racing harnesses, make sure it's a 5 point system.
You'll lose adjustability on the fly when switching to racing buckets.
Old Nov 14, 2006 | 10:00 AM
big pete's Avatar
Default Re: Aftermarket seats? (evil vapor)
any reclinable ones fit? Some say Recaro Speeds/SRD fit and others say they dont
Old Nov 14, 2006 | 10:33 AM
evil vapor's Avatar
Default Re: Aftermarket seats? (big pete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big pete &raquo;</TD></TR><TR><TD CLASS="quote">any reclinable ones fit? Some say Recaro Speeds/SRD fit and others say they dont</TD></TR></TABLE>
I've never tried but space is very limited and I doubt any reclinables would fit.
Old Nov 14, 2006 | 10:36 AM
* B A N N E D *
I know that Bride Brix and Ergos fit, but with a very tight squeeze. Why have reclinables when you don't have space to recline?
Old Nov 14, 2006 | 10:41 AM
gfhb4s2000's Avatar
Default Re: Aftermarket seats? (FR-MOB: Projekt)
i am going to be running the stock 3 point seat belt just need something with some more support for the local race track. I weight about 180pds so i need a seat that i can fit in too and still be able to drive the car every day.
Old Nov 14, 2006 | 10:56 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gfhb4s2000 &raquo;</TD></TR><TR><TD CLASS="quote">i am going to be running the stock 3 point seat belt just need something with some more support for the local race track. I weight about 180pds so i need a seat that i can fit in too and still be able to drive the car every day.</TD></TR></TABLE>
count a very tight fit if you have a waist size over 34-36.
Old Nov 14, 2006 | 10:57 AM
* B A N N E D *
Buddy Club, Mugen, and Sparco make wider seats, but you run into the same fitment/space problem.
Old Nov 14, 2006 | 11:31 AM
gfhb4s2000's Avatar
yah thats what i am affraid of i dont want to go out and spend a bunch of money on seats and then run into the fitment problem. Thanks for the info yall i am going to do some more research before i spend the money
Old Nov 14, 2006 | 11:38 AM
* B A N N E D *
Good call. Find a nice shop with display seats and ask if they can give you test fits.
Old Nov 14, 2006 | 12:08 PM
LaterApex's Avatar
You need to watch two dimensions.
Overall width of the base:
about 19" is the max. This includes any "wing" on the side bolsters that falls below the top of the transmission tunnel.
Sholder Bolster Width:
I think that 21" is the max that will allow the console door to open. I think it's another inch or two that will interfere with the door panel.
Go online and look at the sizing charts for seat makers.
Sparco
http://www.safedrives.com/prod...6.pdf
Recaro Shells
http://www.safedrives.com/prod...s.pdf
The Recaro Speed is one that fits. Be sure not to buy the one fitted for 4-point harnesses.
A lot of the seats on this Miata chart will fit the S2000. Bear in mind that the Miata has about an inch more of base width.
http://www.flyinmiata.com/tech/seats.asp
Regarding a seat for OEM harnesses, I saw an S2000 with the Corbeau A4 in black suede and one in red a while back and they both looked great for the money and the fit was nearly perfect.
slowly slipping away
Apr 21, 2006 07:58 PM
broketuner-Sol_Si
Dec 5, 2005 08:03 PM
turbotime
May 27, 2005 05:13 PM
I Quarantined I
Jan 17, 2005 08:57 PM
ransack
15
Aug 8, 2002 03:13 PM
