Combinding 2 wastegate springs
Old Nov 14, 2006 | 09:05 AM
CustomX113's Avatar
Banned
Default Combinding 2 wastegate springs
i have 2 wastegate springs laying around, a small red one (8psi) spring and a big yellow (4 psi) spring, he told me if you put both of them in the wastegate that the 2 together would run about 12psi off the wastegate.. im not sure about combinding 2 springs but does anyone else know if this is true or not?
Old Nov 14, 2006 | 09:07 AM
ccivic's Avatar
Default Re: Combinding 2 wastegate springs (95dxb18c1)
true. as long as you are combining a small spring and a large spring. you cannot use two smalls or two larges.
Old Nov 14, 2006 | 09:09 AM
CustomX113's Avatar
Banned
the red one fits right inside the yellow one
Old Nov 14, 2006 | 09:31 AM
boosted k20's Avatar
Default Re: (95dxb18c1)
large yellow = 8.7 psi small red = 4.35 psi = about 13 psi
Old Nov 14, 2006 | 09:36 AM
dpetro1's Avatar
yes you can combine the spring, the pressure will equal the sum of the 2 springs. so in your case 12 psi.
are you sure of those spring pressures though? what kind of wastegate is it? generally the smaller springs are lower psi. here's a link to tial's spring chart http://www.tialsport.com/docum...p.pdf
Old Nov 14, 2006 | 09:43 PM
CustomX113's Avatar
Banned
the small red one was in my car for a while and boosted consistant 8psi off the wastegate.. i read on here that the large yellow was good for 4 4.5 psi.. its a tial 38mm wastegate
Old Nov 14, 2006 | 09:54 PM
sleeprhatch's Avatar
DOHC_16v
Aug 3, 2011 01:35 PM
djnikko
May 13, 2009 01:55 PM
cinq
Apr 22, 2004 05:23 PM
