Where can I get some o-rings and gaskets for injectors/manifold???
I'm in the process of a turbo project and I need injector o-rings for 440cc injectors and the intake manifold o-ring gaskets that go into the manifold and the injectors slides into.Any idea where I can pick some of these up and whats the best ones to get??? Thanks
HONDA.
really cheap too.
make sure you buy the correct injector o-rings for your fuel rail.
make sure you buy the correct o-rings for the manifold you are using so that they are spaced properly.
it works best when you use the fuel rail, studs, and manifold that are all from the same engine.
really cheap too.
Your just all over the place ain't ya!!! Thanks.Looks like I'll be hitting the dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xemu »</TD></TR><TR><TD CLASS="quote">Your just all over the place ain't ya!!! Thanks.Looks like I'll be hitting the dealership.
just surfin' the EF section this morning.
</TD></TR></TABLE>just surfin' the EF section this morning.
ImportMotorSpec
Welding / Fabrication
Feb 23, 2007 08:43 AM
Marauder
86
Aug 22, 2003 08:29 AM
