front motor mount ?
Old Nov 14, 2006 | 01:16 AM
661rex89si's Avatar
Default front motor mount ?
i just want to no if the front mount is really needed. i mean well im buying the e-speed motor mounts for the crx with a d-series and they dont come with a front motor mount. plus i notice its alot harder when using turbo dowpipes. thats my other question since im doing a hmt set-up wouldnt it be easier not to have the front mount in place. anybody runing without one.
Old Nov 14, 2006 | 02:35 AM
90_civic_Si's Avatar
Default Re: front motor mount ? (775rex89si)
My front mount is broken and when i`m going down a hill and holding onto the shifter i can feel the motor rocking back and forth. I wouldn`t say it`s a good thing.
Old Nov 14, 2006 | 03:03 AM
gsxr1k05's Avatar
i know a few people who dont use em. i have the stock d series with the stocvk mounts. i just used 3m window weld to siffen em up. work like a champ. almost no shifter movement.
Old Nov 14, 2006 | 05:04 AM
Default Re: (gsxr1k05)
I was gonna buy the inserts but i`ll try the window sealant, a little cheaper.
Old Nov 14, 2006 | 05:57 AM
v8Buster's Avatar
something IS needed to hold the damn engine in place, or ur gonna rip a axle out or soemthing. I just put a new mount on, and when it first came off i could see my shifter litterally moving from front to back RAPIDLY and would sometimes pop out of gear and make me rev in neutral like a dumb ***.
Old Nov 14, 2006 | 06:05 AM
661rex89si's Avatar
**** looks like keeping mine on even with brand new mounts and inserts. thanks for the info guys
Old Nov 14, 2006 | 06:30 AM
janz3n's Avatar
Default Re: (775rex89si)
sorry to thread jack, but im getting a horrible noise from my engine bay when i reverse too hard and sometimes when i intentionally spin my wheels.. sounds kinda like a pop. i noticed my front engine mount is pretty bad. could this noise be the bold hitting the metal of the mount??
Old Nov 14, 2006 | 06:46 AM
Default Re: (janz3n)
I don`t think it would be the bolt hitting, but i`d check all your mounts and just retighten them for fun. A loose mount will defenitly cause a knocking noise when spinning your tires or reversing hard.
Old Nov 14, 2006 | 07:18 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 775rex89si &raquo;</TD></TR><TR><TD CLASS="quote">i just want to no if the front mount is really needed. i mean well im buying the e-speed motor mounts for the crx with a d-series and they dont come with a front motor mount. plus i notice its alot harder when using turbo dowpipes. thats my other question since im doing a hmt set-up wouldnt it be easier not to have the front mount in place. anybody runing without one.</TD></TR></TABLE>
I would use it whenever possible.
I've also never had a problem with it interfeering with any downpipe setup I've done.
When I had only stock mounts and no front mount my motor would lift like a **** on the dyno and jerk a bit when driving. I added the inserts and it got rid of maybe 75% of the lift and jerking. When I added the Innovative front mount it killed the problem 100%...now just waiting on my solid mounts to replace the inserts.
(sidenote: ES inserts + window sealant + freezer= )
Old Nov 14, 2006 | 02:25 PM
janz3n's Avatar
Default Re: front motor mount ? (Autoworks)
can you put window sealent in the mounts with them still in the car? make it so much easier then taking them out one at a time and putting them back in. i dont see why i couldnt do it with them in.
Old Nov 14, 2006 | 05:42 PM
661rex89si's Avatar
well because explicit speed has brand new steel motor mounts with insert for 230 shipped they look killer but they only come without the front mount.
http://www.explicitspeedperfor....html
let me no guys if this is a good deal i think so. what your opinion guys
Old Nov 14, 2006 | 06:33 PM
Autoworks's Avatar
Default Re: front motor mount ? (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">can you put window sealent in the mounts with them still in the car? </TD></TR></TABLE>
That would be a huge mess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 775rex89si &raquo;</TD></TR><TR><TD CLASS="quote">well because explicit speed has brand new steel motor mounts with insert for 230 shipped they look killer but they only come without the front mount.
let me no guys if this is a good deal i think so. what your opinion guys</TD></TR></TABLE>
I think that's a good price. It's possible that the solid mounts could compensate for that movement. You can also add an insert into your OE front mount and make it solid.
I would have picked up a explicit set for my own car if it weren't for the use of Innovative pieces on mine already.
let me no guys if this is a good deal i think so. what your opinion guys[/QUOTE]
Old Nov 14, 2006 | 07:50 PM
janz3n's Avatar
is there a write up on how to put window sealant in the motor mounts? think i searched but couldnt find anything. if i took my time it wouldnt be a huge mess.
Old Nov 14, 2006 | 07:56 PM
salman's Avatar
Go for the Frount mont its very important,
my frineds had a turbo in his car(G1teg) and dont have front mount, he ofen had problem with months and shifter.
Old Nov 14, 2006 | 08:02 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">i know a few people who dont use em. i have the stock d series with the stocvk mounts. i just used 3m window weld to siffen em up. work like a champ. almost no shifter movement.</TD></TR></TABLE>
It's so stiff the car vibrates like a bitch now. I like it though, feels more race car like.
Old Nov 14, 2006 | 10:50 PM
661rex89si's Avatar
im just going to buy the explicit speed mounts and a insert for my front mount. how do you guys do it with aftermarket traction bars since you cant put a front mount
Old Nov 15, 2006 | 03:36 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 775rex89si &raquo;</TD></TR><TR><TD CLASS="quote">im just going to buy the explicit speed mounts and a insert for my front mount. how do you guys do it with aftermarket traction bars since you cant put a front mount</TD></TR></TABLE>
Innovative Mounts has a front mount for the bar.
Old Nov 16, 2006 | 11:20 AM
661rex89si's Avatar
i thought innovative bars were crap though?
i thought they were less functional and more made for room.
Old Nov 16, 2006 | 11:24 AM
661rex89si's Avatar
plus they say there crossmembers are only for b-series engines i have a d-series it would work then
Speed Infliction
Feb 2, 2007 03:29 PM
DANgerous
10
Apr 6, 2006 02:47 PM
TeGGY_LS
Nov 30, 2004 01:05 PM
94gsrhatch
Nov 20, 2004 05:35 PM
90Hatch
Nov 12, 2002 05:22 AM
