SOOOOOOOO STOKED but need a little pressure question answered
well MY whole set up is installed. everything on my signiture is installed and running, YEAAAAAAAAA. BUT noew that i have all that, what should I have my fuel pressure at??? I have it at 40 right now.... more or less. I was think 42-44 would be good but I am not quite sure. thanks
Wow Blow it up..
Please check under fuel pump with a match. It's dark in there. You show always somke a cig when inspecting the fuel system.
4-5 psi above the stock settings seems like a safe guess. Of course, the only way to find out the correct a/f is get a wideband 02 and tune it on the dyno.
thats funny you say that because they were finishing up my nitrous install and the guy was adjust the fuel pressure making sure it would idle right and every time i saw him take the hose off and try smoking his cig and using the wrench at the same time i would laugh
i would have kicked his *** if it was my car.... but anyways....
do you have an a/f gauge? 4-5 psi over stock sounds about right to ballpark it. but tuning it with even a simple a/f gauges would be better than nothing.
-Erik
-Erik
jaredvabeach
Aug 6, 2008 07:38 PM
integrawow
Jul 25, 2007 02:02 PM
