Adjusted Valve clearance. Valve tap still there. What now?
Old Nov 13, 2006 | 08:58 PM
hybrid1990crx's Avatar
Default Adjusted Valve clearance. Valve tap still there. What now?
So I adjusted the valves on my friends 93 si. Stock sohc z6.
I set the intake valves to .008 and the exhaust valves to .010
When we first started it up it sounded decent and then it got warmer and still sounded fine. After a bit it seemed to come back though.
I know I tightened all the locker nuts since I went over all of them one more time before putting the valve cover back on, so I can't see them becoming loose again.
This is the first time I've adjusted the valvs before but its pretty damn straight forward and not hard to do, I followed the helms exactly how it said to do so.
The motor is 'suppose' to have 70k on it but we are not sure for a fact since it didnt have a si cluster on it (no tach).
Where can I go from this?
Old Nov 14, 2006 | 02:31 AM
92ehatch's Avatar
Default Re: Adjusted Valve clearance. Valve tap still there. What now? (hybrid1990crx)
i get the exact same thing
.008 and .010 and at first sounds really good. quiet, no tick.
after about an hour of running it gets loud again.
ive done 3 of em so far and its getting old.
up for answers
Old Nov 14, 2006 | 06:51 AM
instrument's Avatar
did you do it warm or cold?
i believe the stock clearances are set for a cold engine...like letting sit overnight cold.
thats how my uncle taught me...never had a problem.
Old Nov 14, 2006 | 06:58 AM
FuNkDrSpOt's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">did you do it warm or cold?
thats how my uncle taught me...never had a problem.</TD></TR></TABLE>
yep. Motor is supposed to be stone cold
Old Nov 14, 2006 | 07:12 AM
stock_honda_coupe's Avatar
Default Re: (FuNkDrSpOt)
Whatever manual you use, it should say wether the specs are for a hot or cold engine. If it says hot, they mean above 180F, If the say cold, let it get really cold, like leave it set over night or something.
Old Nov 14, 2006 | 08:13 AM
Default Re: (stock_honda_coupe)
I did it cold just like the book says to do.
Old Nov 14, 2006 | 10:09 AM
Hater's Avatar
Default Re: (hybrid1990crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">I did it cold just like the book says to do.</TD></TR></TABLE>
I know you said stock, but does the car have an aftermarket intake? The OEM waffle tubing and air box is meant to to keep all intake and valvetrain noise to a minimum. Honda's mechanical valvetrain is always noisy and clicky in the first place...
I would almost be inclined to say that this is normal... You could check the LMA's but I'm not sure how loud those would ever really get at idle...
Old Nov 14, 2006 | 10:14 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i have found that some of the higher mileage motors tap regardless if you set valve lash proper. i just went over a vehicle i have that has 137k, and i did the v-adjust 3x because there was still an audible tap. i will have to just live with it.
Old Nov 14, 2006 | 10:41 AM
Default Re: (Hater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hater &raquo;</TD></TR><TR><TD CLASS="quote">
I would almost be inclined to say that this is normal... You could check the LMA's but I'm not sure how loud those would ever really get at idle... </TD></TR></TABLE>
Well the car is undergo alot of work, we didnt even have the intake on at the time. so it was just open TB.
I told him honda's are known to tick but hes stubborn.
Old Nov 14, 2006 | 10:53 AM
Hater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">Well the car is undergo alot of work, we didnt even have the intake on at the time. so it was just open TB.
I told him honda's are known to tick but hes stubborn.</TD></TR></TABLE>
You will definitely hear the valvetrain noise if it is an open throttle-body, even if they are properly adjusted... After tens of thousands of miles, the valve springs tend to lose their snap which can result in a bit of laziness, which may cause a bit of additional noise...
I'd say reassemble it and be done. If they are within specifications then that's all that you can do.
Old Nov 14, 2006 | 10:54 AM
Rodney's Avatar
Default Re: (Hater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hater &raquo;</TD></TR><TR><TD CLASS="quote">I'd say reassemble it and be done. If they are within specifications then that's all that you can do. </TD></TR></TABLE>
lazyxmofo
May 23, 2012 07:04 PM
85_305
21
Jan 12, 2009 01:51 PM
Chris N
Aug 7, 2003 11:55 AM
typesguy
Aug 7, 2003 11:00 AM
Pineapple Devil
Dec 28, 2002 08:28 AM
