absolute max rev limit?
Old Nov 13, 2006 | 07:05 PM
type B16's Avatar
Default absolute max rev limit?
im planning my all motor build on my jdm itr.
ill be building the head to handle 10k but ill be leaving the stock block.
whats is the absolute max rpm the stock jdm itr block can handle without blowing **** up? what is the "least" that can be done to it to handle higher revs? reason why im asking least is because i plan to build the block later on as a 2L so i dont want to spend money on something ill end up replacing anyway for the future build?
Old Nov 13, 2006 | 07:13 PM
Dave_B's Avatar
Default Re: absolute max rev limit? (type B16)
RPM doesn't necessarily mean Power. Do a little more research on it.
Old Nov 13, 2006 | 07:15 PM
type B16's Avatar
Default Re: absolute max rev limit? (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">RPM doesn't necessarily mean Power. Do a little more research on it.</TD></TR></TABLE>
well the cams peak at 9k-9.5k
i want to know if the block can handle it without a big KABOOM.
Old Nov 13, 2006 | 07:17 PM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">
i want to know if the block can handle it without a big KABOOM.</TD></TR></TABLE>
Built properly yeah, I think the block will hold those RPM's. It really comes down to the quality of the build (including machine work) and the tuning.
Old Nov 13, 2006 | 07:23 PM
type B16's Avatar
tuning of course, but stock block. can the block handle 9500rpm on a occasional rip?
Old Nov 13, 2006 | 07:33 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
i'd say at least 15 K. well, 20 K since its a jdm block
Old Nov 13, 2006 | 07:36 PM
rino924's Avatar
Community Builder
Default Re: absolute max rev limit? (rino924)
sorry for the wise *** comment, i've been studying in the library for about 6 hours
what are your plans for tuning? that is going to be critical. I'd say why not upgrade the bottom end, might as well do everything. yeah, its more expensive, but in the end worth it. maybe list some of the plans you already have? someone may have something similar and be able to assist you better
hope thats better than the last post
Old Nov 13, 2006 | 07:40 PM
type B16's Avatar
i cant afford any down time on my car as its my only daily driver for work and school. this is why im only building the head mildly. i plan on getting it crome dyno tuned
current list
stock jdm itr
3" magic stick
2.5 omni pipe and straight through exhaust
chipped p06
jdm 4-1
plans
m22x cams
rocket sl valvetrain
cam gears
crome tuning
Old Nov 13, 2006 | 07:47 PM
Amped's Avatar
honda motors make the most power around 8 grand or low 9's, atleast from what i've seen
nice build here.
https://honda-tech.com/zerothread?id=1607086
Old Nov 13, 2006 | 08:32 PM
totsie7944's Avatar
Default Re: absolute max rev limit? (Amped)
it'll handle the occasional 9.5 rpm rip....but I wouldn't do it often, even with a built head AND block I don't reccomend giving ANY car 9.5 rpms and higher a whole lot.
Honestly I would set the rev limiter to like 9300 to be safe, but it'll handle it.
Old Nov 13, 2006 | 11:09 PM
itr1244's Avatar
Default Re: absolute max rev limit? (totsie7944)
i set it at 9125 just to be safe side
and i barely rip it to 9000..
but yeah you can rev it to 13000 rpm your bottom end will be ok..
i hope you blow your motor doing that
Old Nov 13, 2006 | 11:15 PM
TEXASITR603's Avatar
the answer to your problem http://cgi.ebay.com/Tamiya-Sup...94450
Old Nov 13, 2006 | 11:17 PM
itr1244's Avatar
Default Re: absolute max rev limit? (TEXASITR603)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXASITR603 &raquo;</TD></TR><TR><TD CLASS="quote">the answer to your problem http://cgi.ebay.com/Tamiya-Sup...94450
bullshit. where does it say that?
Old Nov 13, 2006 | 11:20 PM
Default Re: absolute max rev limit? (itr1244)
because i have one
Old Nov 13, 2006 | 11:46 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">stock jdm itr
3" magic stick
chipped p06
jdm 4-1
plans
m22x cams
cam gears
crome tuning</TD></TR></TABLE>
Those cams will not peak above 8500 with that header and a stock head, so no reason to revv that high.
Old Nov 14, 2006 | 03:59 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">whats is the absolute max rpm the stock jdm itr block can handle without blowing **** up? what is the "least" that can be done to it to handle higher revs? QUOTE]
[QUOTE=type B16]i cant afford any down time on my car as its my only daily driver for work and school. </TD></TR></TABLE>
I don't think these go together...
Old Nov 14, 2006 | 04:06 AM
RTW DC2R's Avatar
revving out the stock block isnt the best idea.
put it on a dyno and set the limiter at peak hp. but if its still making power past 9K I would stop there on a stock block. I doubt it will make power past that anyway on stock compression.
your stock rods will end up looking like this and trust me you do not want this...
Old Nov 14, 2006 | 04:47 AM
vtec.dc2's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">revving out the stock block isnt the best idea.
agree. focus on hp instead of high rpm. revving the car faster doesn't mean you're going to make more hp.. but you're definately going to put extreme wear and tear on drivetrain by doing that.
Old Nov 14, 2006 | 05:08 AM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">i cant afford any down time on my car as its my only daily driver for work and school</TD></TR></TABLE>
Take that PS3 money and buy a beater, then concentrate on your build. If you can't afford downtime, leave the car stock. Or buy a bus pass.
Old Nov 14, 2006 | 12:48 PM
Hooch'n's Avatar
Default Re: absolute max rev limit? (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
Take that PS3 money and buy a beater, then concentrate on your build. If you can't afford downtime, leave the car stock. Or buy a bus pass.</TD></TR></TABLE>
Yep.....also b16A 9,100rpm all day long yoooooooooooo
Old Nov 14, 2006 | 12:52 PM
EG6-DC2's Avatar
Default Re: absolute max rev limit? (Hooch'n)
Why put a limit on the revs? Just keep going until you want to shift! Me, I personally wouldn't take it much past the stock redline.
Old Nov 14, 2006 | 12:56 PM
Hooch'n's Avatar
Default Re: absolute max rev limit? (EG6-DC2)
it only makes power to 9100......
Old Nov 14, 2006 | 01:05 PM
EG6-DC2's Avatar
I don't know why people are so fascinated with RPM's. Alot of people in the S2k clique don't liek the AP2's because they only have an 8k redline. I had an AP2 and I know for a fact that it was quicker than my friends AP1 stock to stock with a 9k redline. People just need to stop being so hung up on how high they can rev. Higher does not always mean more power!
Old Nov 14, 2006 | 01:58 PM
type B16's Avatar
reason why im interested in a higher rev limit is because of the cams. if the cams make power past the stock redline, then it should be revved higher. if the cams peak at stock redline, then yes theres no reason to rev higher.
Old Nov 14, 2006 | 02:01 PM
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">reason why im interested in a higher rev limit is because of the cams. if the cams make power past the stock redline, then it should be revved higher. if the cams peak at stock redline, then yes theres no reason to rev higher.</TD></TR></TABLE>
ok so. shut up
j/k
yeah so go take it to dyno and find out for yourself and tell us what the redline is
