so what could this be
Old Nov 13, 2006 | 06:51 PM
jdmcivicsi522's Avatar
Default so what could this be
so i might be buying a 91 rs with 90k original miles head short ram and some coilovers. but here is what im wondering i took it for a drive and when it starts cold it smokes white. then when i was driving it i got on it alittle and alot of white smoke came out what is that? aslo is it worth it? im getting it for $600 and im doing the body work and painting his truck. so what do you guys think. need to know quick what the smoke might be casue im going to get it this week or next. thanks alot
Old Nov 13, 2006 | 07:00 PM
Micha's Avatar
FAILWGN
Default Re: so what could this be (jdmcivicsi522)
Does the smoke smell sweet?
Old Nov 13, 2006 | 07:58 PM
ari.'s Avatar
Default Re: so what could this be (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicsi522 &raquo;</TD></TR><TR><TD CLASS="quote">what im wondering it starts cold it smokes white. </TD></TR></TABLE>
NaWZzz!!!!!!!!!!!!!!!!111!!!!
Old Nov 13, 2006 | 08:01 PM
DirtyBirdJR's Avatar
Default Re: so what could this be (skinnyshugg [V2])
correct me if I am wrong but I think white smoke is steam. It might have a blown headgasket.
Old Nov 13, 2006 | 08:10 PM
lsvtek's Avatar
Default Re: so what could this be (DirtyBirdJR)
I think it is headgasket also
Old Nov 13, 2006 | 08:12 PM
LoseRPunKx182's Avatar
Default Re: so what could this be (LSintegra4)
coolant
Old Nov 13, 2006 | 08:18 PM
Default Re: so what could this be (LoseRPunKx182)
so more than likly its just a head gasket? and do you guys this its worth it? and it needs a alternator
Old Nov 13, 2006 | 08:28 PM
CleanLikeJdm's Avatar
Hype-R Stalker
600, without the favor of you painting his truck.
Try driving it again, if it was burning oil, you would Definitely smell it.
Headgasket is a lot easier to change then rings, or valve seals though.
Old Nov 13, 2006 | 08:35 PM
Default Re: so what could this be (CleanLikeJdm)
i know its not burning oil and i think he did say somthing about he had to keep refilling the coolant. i have been a eg guy so is the car worth it?
Old Nov 13, 2006 | 09:07 PM
blackdelslo's Avatar
Sounds like a headgasket.
Old Nov 13, 2006 | 09:10 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicsi522 &raquo;</TD></TR><TR><TD CLASS="quote">i know its not burning oil and i think he did say somthing about he had to keep refilling the coolant. i have been a eg guy so is the car worth it?</TD></TR></TABLE>
With only 90k original miles, it's a decent price.
If the job for doing his truck isn't something like 2k worth of work, then yes.
I don't think I'd pay more then 1500 because of the need to replace the Headgasket.
Old Nov 13, 2006 | 09:24 PM
dvp's Avatar
dvp
Usually white smoke is water and blue smoke is oil. If it's fully warmed up and still kicking out white smoke then yes, that is most likely water.
Old Nov 13, 2006 | 10:33 PM
97CGPintegra's Avatar
the coolant is leaking through the head gasket causing the coolant to mix with the engine oil. if he hasn't been driving since the white smoke than it should be ok. just replace the head gasket flush out the oil with some gunk engine cleaner, flush the coolant and it should be cool. DA with only 90k can probably sell for about $3-4k if it's clean and running well.
Old Nov 14, 2006 | 02:39 PM
Default Re: so what could this be (97CGPintegra)
the body work is only about 100 bucks worth and the i only charge 300 bucks for a paint job so all in all im only doing 900 for the car. thanks for the info guys if i get it ill post up some pics.
llozll
Honda S2000
Oct 3, 2009 08:47 PM
JDMHondaEJ8
52
Apr 29, 2008 03:33 PM
Enzo PR
Jan 1, 2006 08:13 PM
Civic Hx-T
13
Apr 14, 2005 05:15 PM
plastik462003
May 24, 2003 10:47 AM
