Suspension & Brakes Theory, alignment, spring rates....
best daily driver suspension?
Old Nov 13, 2006 | 06:32 PM
type B16's Avatar
Default best daily driver suspension?
im not a autox *****. im not a drag strip *****. i use my car everyday.
what im looking for is a suspension that wont kill my wallet. all i need is a suspension that can offer a 50/50 combination of stiffness/comfort for the daily drive. a kit that is soft enough for a nice ride and stiff enough to prevent a gangster squat/lean during takeoff and turns.
i also plan to keep a stock height because i like not worrying about scraping.
Old Nov 14, 2006 | 02:51 AM
type B16's Avatar
bump
Old Nov 14, 2006 | 08:03 AM
future62
Guest
Posts: n/a
Default Re: (type B16)
I love my Neuspeed Sports and Koni Yellows. Pricey, but perfect ride and handling wise.
STN_Pat's Avatar
you want the OEM suspension combo.
Old Nov 14, 2006 | 11:23 AM
ED3_FTW's Avatar
Default Re: best daily driver suspension? (type B16)
get softer rates but bigger sway bars, it will handle well and not jar your teeth,
cam be tricky to get the right combo going though
Old Nov 14, 2006 | 11:27 AM
E-Money's Avatar
like said before, get a nice OEM bar, aftermarket
Get some konis mated with eibach pros, run them on the softest setting and still handles sweet
Old Nov 14, 2006 | 11:46 AM
Tyson's Avatar
stock springs, tokico illuminas, 22mm rear swaybar and stock 19mm front swaybar. i love it.
Old Nov 14, 2006 | 12:28 PM
E-Money's Avatar
add some sticky tires to the mix
Old Nov 15, 2006 | 05:10 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: best daily driver suspension? (E-Money)
cannot get coilovers and keep stock height, the shock bodies are shorter. get type R lcas, struts/springs and some sway bars.
Old Nov 15, 2006 | 09:21 AM
FalkenSiR's Avatar
Default Re: best daily driver suspension? (Mr.OB*GYN_Rhett)
OTS GC rate coilover sleeves on stock shocks at stock/close to stock height. Tighter steering with much better response. Add a rear sway if you don't have one (assuming you have a front)
had this setup for 1.5 years
TOO MUCH TORQUE
Suspension & Brakes
24
Mar 7, 2012 04:59 PM
MissShift
14
Aug 5, 2011 11:10 AM
BMRALR
Suspension & Brakes
Nov 22, 2007 08:10 PM
type B16
Nov 14, 2006 07:28 AM
DeDonDeRosa
Suspension & Brakes
10
Oct 3, 2005 08:41 AM
