15x8 4x100 Sportmax 002 Wheels Question
Old Nov 13, 2006 | 06:30 PM
InfraRed's Avatar
Default 15x8 4x100 Sportmax 002 Wheels Question
will i be able to fit an 8" rim without any modifications on my 92 Hatch?
im trying to go with the 8" over the 7" so i can get the 3 1/2" lip on the rim.
thanks alot
Old Nov 13, 2006 | 11:06 PM
vtecsi00's Avatar
Default Re: 15x8 4x100 Sportmax 002 Wheels Question (InfraRed)
need to know what the offset is??????? to be of more help
Old Nov 14, 2006 | 05:41 AM
InfraRed's Avatar
Default Re: 15x8 4x100 Sportmax 002 Wheels Question (vtecsi00)
+ 0 offset
Old Nov 14, 2006 | 07:43 AM
old man neri's Avatar
I tried to help him out here:
https://honda-tech.com/zerothread?id=1809706
Old Nov 14, 2006 | 10:32 PM
vtecsi00's Avatar
Default Re: 15x8 4x100 Sportmax 002 Wheels Question (old man neri)
stock wheels came with a 4.5 inch backside..which is from the hub towards your inner fender..which leaves 1.5 inches from the hub to your outer fender...
now the 15x8 with a zero offset is going to have 4.5 inches towards your inner fender and also leave 4.5 inches from your hub to your outer fender....
what i would do is pull your wheel off and take a ruler and measure from the outer hub to the outer fender and see how much room you will have ....my money says it will work with a 195/50r15 but could rud depending on how much your car is lowered
Old Nov 15, 2006 | 06:45 AM
InfraRed's Avatar
alright thanks man. ill try later today.
Old Nov 15, 2006 | 11:30 PM
vtecsi00's Avatar
let me know how it went
Old Nov 16, 2006 | 01:14 AM
r.wright's Avatar
will need plenty of negative camber, rolled fenders, stretched tires and they still wont fit under the stock fender w/ that width, offet. i am usually a big fan of low offset rims but with these rims on a honda i think they will just look rediculous.
Old Nov 16, 2006 | 07:56 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfraRed &raquo;</TD></TR><TR><TD CLASS="quote">will i be able to fit an 8" rim without any modifications on my 92 Hatch?</TD></TR></TABLE>
No. Your car needs 195/50-15 size tires. That size is approved only for wheels that are 5.5-7.0 inches wide.
fizzle
Jan 6, 2012 10:04 PM
2000HondaEm1
Sep 14, 2009 09:10 PM
matt94z
Aug 7, 2008 05:03 PM
eurocouture
11
May 3, 2006 08:29 AM
carl_aka_carlos
Jul 16, 2002 12:29 PM
