motor is hitting crossmember
ok i have a 89 hatch with a jdm b16a swap. the drivers side corner of the block is hitting the strut bar and the crossmember badly. the car vibrates like a motha *****. is there a differant cross member i should be using? i did not do the swap but the mounts look kinda cheap. is it a possibility that the mounts are just mounting the motor too low in the engine bay?
?!?! huh.... What mount kit did you use? jeeeesus
And if you don't know - replace them.
i dont know. like i said i bought the car with the motor in in. they look cheap. i remember my one buddies hatch his b16 sat high that he had to cut the supports out of the hood. id rather have that problem.
hondaon18's
May 27, 2009 09:59 AM
KOALA YUMMIES
Jun 21, 2003 10:06 PM
