mpfi swap
Old Nov 13, 2006 | 03:40 PM
BlueRex1020's Avatar
Default mpfi swap
a friend of mine and I r doing the mpfi swap for my cus's hatch....were using a ported eg manifold, obd0 ls injectors, ls throttle body, crx si dizzy, and a pg7 ecu....wat u guys think? would it run good?
Old Nov 13, 2006 | 04:27 PM
Default Re: mpfi swap (BlueRex1020)
anyone?
Old Nov 13, 2006 | 04:38 PM
Rex-Si's Avatar
hope this helps............................
http://www.50mod.com/fourthgenhatch/mpfi.html
Old Nov 13, 2006 | 04:54 PM
Default Re: mpfi swap (Rex-Si)
oh my friend knows about the wiring, i was jus wondering if it will run better with the stuff were using...
Old Nov 13, 2006 | 05:36 PM
NikoZai's Avatar
well, porting a manifold but not the head will help, as the intake manifold is sliiightly restrictive. But not as much as if the head is port matched as well.. Think about it. big hole at the beginning, small hole at the end - You're restricted by the smallest point - doesn't matter how big you make the rest of it.
LS injectors instead of CRX Si injectors? ... they're the same thing. No difference.
LS Throttle Body certainly isn't benefiting the ported intake manifold. Refer to previous statement. Smallest point etc...
Basically. sounds like it will run exactly like stock. Bunch of mixin and matching, even some porting and I predict absolutely no gains above a normal MPFI swap.
Old Nov 13, 2006 | 05:47 PM
extensioncordy's Avatar
that ecu is made for a dohc zc and im thinking ur gunna be running a bit rich
Old Nov 14, 2006 | 07:34 PM
Default Re: (extensioncordy)
thanks for the input guys
EKdriverin703
Mid-Atlantic (Sales)
Aug 16, 2010 07:31 PM
1SIKEF8B20VTEC
Aug 24, 2005 04:17 AM
BlackThorN
Jan 29, 2004 05:49 AM
DjFreeze
Dec 9, 2003 06:43 AM
