Does an LS throttle body/ IM fit a d16?
i have a D16z6 in my car now, and i got alot of ls parts can i use the ls throttle body and/or the ls intake manifold (w/ injectors and everything?)
Re: (DjFreeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjFreeze »</TD></TR><TR><TD CLASS="quote">what would the pros/cons be of this? </TD></TR></TABLE>
On a stock motor none
On a motor with bolt on's minimal
On a motor with revamped internals it would be great.
Re: (SOHC_MShue)
also the injectors on the ls are how much bigger then my stock d16 injectors. Also since were on the topic any other parts from an ls universal between the two?
Re: (DjFreeze)
i actually think the injectors are the same size, 240cc, but i might be wrong cause i just woke up . i have an ls tb on my z6. get an ls tb gasket and port out the manifold when u bolt on the tb. i had my tb installed at the same time i got a 12lb flywheel. between the2 of them the throttle response is amazing and the car revs so much better now. get the tb
Re: (blackeg)
well i got the tb now cause i have a 95 b18b head assembly so i got everything. so your saying the injectors are both the same size?
brizjuan
05-05-2004 06:30 PM
