head gasket parts list?
Old Nov 13, 2006 | 02:21 PM
93formula's Avatar
Default head gasket parts list?
got a blown head gasket i was wondering if someone could direct me or give me a parts list, i did a search under my titles and got nothing.
i know ill need a head gasket, it was blown, driven for a bit a friend, does it need to be resurfaced? i know with domestics we always resurface the heads.
so other parts, will be timing belt, waterpump, and i know ill need misc seals, can someone post which ones ill need?
car is a 92 d15b7 hatch BTW.
Old Nov 13, 2006 | 02:30 PM
t0p_sh0tta's Avatar
Default Re: head gasket parts list? (93formula)
The only thing that NEEDS to be replaced is the head gasket and the coolant. The water pump doesn't need to be removed.
You can't tell if the head/deck is warped until you pull off the head.
p.s. replacing the head bolts is recommended, as they are stretch bolts.
Old Nov 13, 2006 | 02:58 PM
93formula's Avatar
Default Re: head gasket parts list? (t0p_sh0tta)
thanks supposedly the waterpump went the car overheated and the headgasket blew shortly thereafter which is why were doing the waterpump as well as the timing belt, i found the walk thru via search but i havent found a parts list yet, i remember i did this a while back on my d16a6 but i dont remeber all the parts we replaced, there was a bunch of seals we changed while we were at it.
just for safteys sake this is the second head gasket failure on this car in a years timespan so im assuming the head should be resurfaced. ill be sure to replace the head bolts as well, thanks, any more tips guys.
Old Nov 13, 2006 | 03:52 PM
t0p_sh0tta's Avatar
The only seals that I can think of that could have been replaced are the valve cover gasket and the individual spark plug tube seals.
Just make sure you use a new gasket with the water pump and that the block isn't warped also.
Old Nov 13, 2006 | 04:19 PM
93formula's Avatar
thanks for the tips, is the block warping common?
Old Nov 13, 2006 | 10:12 PM
93formula's Avatar
anyone else?
valve cover gasket, plug seals, intake gasket, wp gasket, timing belt, wp, head bolts.
im sure im missing something, LOL
Old Nov 17, 2006 | 08:18 AM
93formula's Avatar
is that is guys, i have everything covered?
milos
Honda Civic (2001 - 2005)
29
Jul 27, 2014 08:21 PM
kris9
Mar 21, 2010 05:13 AM
PushnFords
Nov 4, 2007 08:19 AM
Defcon2030
Aug 20, 2007 07:11 AM
TurBoXBirD16
Apr 15, 2003 09:30 PM
