additives to mt oil?
Since engine oil is used in the manual trans, and my 250k old trans may be leaking through a seal or two...
1)
would a engine oil additive to recondition seals be a good or bad idea?
note, I am not speaking of a thickener.
2)
would a ptfe additive be good or bad?
3)
would "high mileage" oils contain seal conditioners?
as usual, I appreciate any input
Modified by HondaHeddie at 4:59 PM 11/13/2006
1)
2)
3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Replace the seals, use GM syncromesh or the new advanced Honda MTF. </TD></TR></TABLE>
I will replace the seals when I have time to pull the trans and that will also be a rebuild cuz there are reasons to do so if I have the thing pulled open
I plan to change gearing as well. This will have my wallet and my car down longer than I can deal with now.
synchromesh and Honda MTF are nowhere near the same thing,
I would never go that far over the weight of the spec oil for my trans so synchromesh is way out of the question
I will look into the New Honda MTF
I would like the 3 questions I asked answered, please.
I do appreciate your response though ludesrv
Modified by HondaHeddie at 5:13 PM 11/13/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">a lot of people use lucas trans oil stabilizer. i use it and like how it stops leaks from the axle seals</TD></TR></TABLE>
Thank you
I will try the synth ver of Lucas
Thank you
Alex_C
33
Oct 31, 2008 11:04 AM
HA0LEFIED
Honda Civic (2006 - 2015)
13
Jan 10, 2008 08:52 AM
Nytmair
Jun 6, 2005 11:29 AM
