1/4 mile expectations for a allmotor ep3 civic with 270whp.
Old Nov 13, 2006 | 01:18 PM
jdm knight's Avatar
Default 1/4 mile expectations for a allmotor ep3 civic with 270whp.
I'd like to know if a ep3 civic would be able to run 11 seconds or at least close to that time at the track with 270whp.
Old Nov 13, 2006 | 01:42 PM
cnyej1's Avatar
Default Re: 1/4 mile expectations for a allmotor ep3 civic with 270whp. (jdm knight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm knight &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to know if a ep3 civic would be able to run 11 seconds or at least close to that time at the track with 270whp.</TD></TR></TABLE>
Like 11.0 or 11.99?? Thats a pretty big difference.
270whp would be nice as long as you can hook up properly.
There are guys over at Ephatch that are running low 13's high 12's with about 250-270whp. 11's you better be bring ing in at least 320whp and a good driver.
Another problem with your question is this: Are you talking about with the stock k20a3 and oem 5pd? Or are you talking a k20a2 with that power and the 6spd? That WILL make a difference.
Old Nov 13, 2006 | 02:01 PM
jdm knight's Avatar
Default Re: 1/4 mile expectations for a allmotor ep3 civic with 270whp. (cnyej1)
I'm talking about high 11's to low 12's, the set up would be a sleveed k24 bottom end with high compression pistons and a build k20a2 head with 6sp transmisson.
Old Nov 13, 2006 | 02:09 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm knight &raquo;</TD></TR><TR><TD CLASS="quote">I'm talking about high 11's to low 12's, the set up would be a sleveed k24 bottom end with high compression pistons and a build k20a2 head with 6sp transmisson.</TD></TR></TABLE>
Short answer NO. I dont think you'll hit the 270whp allmotor. Also are you talking a fully gutted Ep3? I would hope so.
Old Nov 13, 2006 | 04:02 PM
dc5r28's Avatar
You could get that kind of power out of an all motor car. You just need a lot of time and money to get there. and you could hit mid to low 12's with slicks.
Old Nov 15, 2006 | 06:08 AM
cnyej1's Avatar
Default Re: (dc5r28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5r28 &raquo;</TD></TR><TR><TD CLASS="quote">You could get that kind of power out of an all motor car. You just need a lot of time and money to get there. and you could hit mid to low 12's with slicks.</TD></TR></TABLE>
The guys that are getting the times I posted are on slicks.
Old Nov 15, 2006 | 07:43 PM
Andrey's Avatar
guy over at ephatch ran 13.2 with 230whp.
But honestly I think 270 will put u in mid 12's.
For high 11's u need to loose a lot of weight. Just look at nikos's car eg shell with ~270whp N/A he runs like mid-high 11's
Old Nov 15, 2006 | 07:58 PM
bmoua's Avatar
i'd say with that much power...i'm guessing 13's...and thats with full interior...maybe with gutted interior, good tires, and a good driver you may hit mid 12's on a lucky run...
Old Nov 15, 2006 | 08:00 PM
Andrey's Avatar
just build 320 whp k26 N/A and you will proly hit 11's!!!
Old Nov 16, 2006 | 08:09 AM
Azcheron's Avatar
Default Re: (Andrey)
270 whp out of a K all motor isnt THAT hard
you can get 270 out of a b18c5 with way too much money and time
so it has to be easier on a K
Old Nov 16, 2006 | 08:11 AM
cnyej1's Avatar
Default Re: (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">270 whp out of a K all motor isnt THAT hard
so it has to be easier on a K</TD></TR></TABLE>
Who said it was hard?
Old Nov 27, 2006 | 03:21 PM
blkhtch98's Avatar
Default Re: (cnyej1)
what kind of whp and 1/4 mile times will i get with my N/A setup of a *k24a4 sleeved, with type-r intak mani, cp high compression pistons, eagle H beam rods, skunk2 stage 2 cams, act flywheel stage 2 exedy clutch stage 2 with pressure plate, 5 speed tranny with lsd, kpro??? how bout numbers for that?
then how about numbers with all that running with a tuned 50 shot (wet) of no2 on the kpro???? thanks 4 the answers guys i just need a few more things to finish my build but that everything.
Old Nov 27, 2006 | 03:26 PM
cnyej1's Avatar
Default Re: (blkhtch98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhtch98 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of whp and 1/4 mile times will i get with my N/A setup of a *k24a4 sleeved, with type-r intak mani, cp high compression pistons, eagle H beam rods, skunk2 stage 2 cams, act flywheel stage 2 exedy clutch stage 2 with pressure plate, 5 speed tranny with lsd, kpro??? how bout numbers for that?
then how about numbers with all that running with a tuned 50 shot (wet) of no2 on the kpro???? thanks 4 the answers guys i just need a few more things to finish my build but that everything.</TD></TR></TABLE>
How the hell would we know? Honestly, you have an Accord motor, which is 160hp stock, and about 145whp stock. So maybe 195-200whp. 1/4 mile....if you can drive, on street tires, low 14's.
Old Nov 27, 2006 | 04:06 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">
Who said it was hard?</TD></TR></TABLE>
troof, $$$ owns you
Old Nov 28, 2006 | 01:34 PM
blkhtch98's Avatar
"How the hell would we know? Honestly, you have an Accord motor, which is 160hp stock, and about 145whp stock. So maybe 195-200whp. 1/4 mile....if you can drive, on street tires, low 14's."
i highly doubt u know what ur talking about im running a 35shot on my a3 with I/H/E no kpro and run 14.3 slips to prove at union grove wisconsin
Old Nov 28, 2006 | 01:51 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhtch98 &raquo;</TD></TR><TR><TD CLASS="quote">"How the hell would we know? Honestly, you have an Accord motor, which is 160hp stock, and about 145whp stock. So maybe 195-200whp. 1/4 mile....if you can drive, on street tires, low 14's."
i highly doubt u know what ur talking about im running a 35shot on my a3 with I/H/E no kpro and run 14.3 slips to prove at union grove wisconsin</TD></TR></TABLE>
Yeah and with those mods people over at ephatch our putting out about 185-190whp. So i do know what I am talking about. So yes, low 14's with 195-200whp is about right. people with k20a's are running in the low 14's and they have about 200whp with bolt-ons. Go check it out over there if you dont believe it.
Old Nov 28, 2006 | 05:13 PM
blkhtch98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah and with those mods people over at ephatch our putting out about 185-190whp. So i do know what I am talking about. So yes, low 14's with 195-200whp is about right. people with k20a's are running in the low 14's and they have about 200whp with bolt-ons. Go check it out over there if you dont believe it.</TD></TR></TABLE>
i just dont know cuz im running mid 14's with bolt ons and 35 shot and this new motor will be built with a bigger shot so it has to be better times than what i am now
Old Nov 28, 2006 | 05:26 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Reading owns me a little. I didnt notice that you said u wanted numbers running a 50 shot too. With the 50 id say you would dip into the mid 13's If you can drive it.</TD></TR></TABLE>
That accord motor does have alot more torque so you get a better power band that is smoother. Reading owns me a little. I didnt notice that you said u wanted numbers running a 50 shot too. With the 50 id say you would dip into the mid 13's If you can drive it.
Old Nov 30, 2006 | 06:53 AM
touge_dc5's Avatar
is drag racing really this important to you guys?
Old Nov 30, 2006 | 06:55 AM
cnyej1's Avatar
Default Re: (touge_dc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touge_dc5 &raquo;</TD></TR><TR><TD CLASS="quote">is drag racing really this important to you guys?</TD></TR></TABLE>
Is making useless non-contributing comments important to you.
Old Nov 30, 2006 | 06:57 AM
touge_dc5's Avatar
pretty much
becase i feel it important to rag on drag racing
Old Nov 30, 2006 | 07:15 AM
cnyej1's Avatar
Well go be 17 in some other thread since your not posting anything helpful etc, hell go out tougeing in your Dc5.
Old Nov 30, 2006 | 08:45 AM
huevosrancheros's Avatar
Mid 12's, if you have the drivetrain hook'd up, and if you are good behind the wheel.
Old Nov 30, 2006 | 08:46 AM
Old Nov 30, 2006 | 12:33 PM
A2gt35r's Avatar
With 300 FI whp, LSD, & slicks I got a 12.6 with a 1.8 60. You'll need a quaife, slicks & a 1.7 or lower to hit low 12's.
BTW drag racing is that important to the little expletive who can't shut his face!
