rattle noise from valves problem
Old Nov 13, 2006 | 01:06 PM
ge_itr's Avatar
Default rattle noise from valves problem
i have an h22 and it has recently been making some rattling noise from the valves. it gets louder as you rev it up a little. can this be just be some adjustments on the valve lash? if it is... how much will it cost if i take it to the shop?
Old Nov 13, 2006 | 01:34 PM
1GPlusSH's Avatar
Default Re: rattle noise from valves problem (ge_itr)
It could be. What kind of fuel are you buying...what brand? If you're buying the cheapo gas, it could be making your valves rattle. All gas companies don't purify their fuel the same way or through as extensive processes as the others.
Old Nov 13, 2006 | 01:42 PM
ge_itr's Avatar
Default Re: rattle noise from valves problem (1GPlusSH)
not sure of what brand but alway premium. i add a bottle of fuel injector cleaner about every other month or so.
Old Nov 14, 2006 | 04:09 PM
1GPlusSH's Avatar
Certain fuel companies put starches and cleaners in their fuel, too. I only buy from the top three. If you don't, at least run it every once in awhile. BP, Amoco(they are NOT the same) and Shell. Amoco and Shell run 5 processes to clean the fuel. BP runs 4. Texaco has an okay system. I wouldn't buy from anywhere else. You're valves may still be out of adjustment, but if they are pinging because of bad fuel, I'd buy from one of these. Premium does not equal premium.
Old Nov 14, 2006 | 08:34 PM
97 Sleeper's Avatar
i know this is not the same but on my dads F150 the valves rattle on a certain gas and dont on another...same concept thou
Old Nov 15, 2006 | 09:02 PM
ge_itr's Avatar
Default Re: rattle noise from valves problem (97 Sleeper)
i usually go to different gas stations all the time. but it rattles on all of them. maybe just not as loud on some, but not sure?
Old Nov 16, 2006 | 07:51 AM
1GPlusSH's Avatar
Well, like I said, you just might have to adjust your valves.
Old Nov 16, 2006 | 12:34 PM
94Vtecluder's Avatar
What do you think about Mobil gas, gas guru?
Old Nov 17, 2006 | 11:56 AM
90acc-lude's Avatar
Default Re: rattle noise from valves problem (94Vtecluder)
I HAVE THE SAME PROB. WITH MY H22. I WENT THROUGH THE WHOLE GAS DEAL ALSO. STILL RATTLES AROUND 3-5K RPMS. ANY INFO ON ADJUSTING VALVES???
Old Nov 17, 2006 | 12:41 PM
ge_itr's Avatar
Default Re: rattle noise from valves problem (90acc-lude)
i know it's the valve lash, but i don't have the tools and the time.
how much will it cost to get it done at the shop? what is a good deal on it?
Old Nov 17, 2006 | 12:46 PM
JasonST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90acc-lude &raquo;</TD></TR><TR><TD CLASS="quote"> ANY INFO ON ADJUSTING VALVES???</TD></TR></TABLE>
Search is your best friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by &raquo;</TD></TR><TR><TD CLASS="quote">Your search for valve adjustment returned 939 results.</TD></TR></TABLE>
Old Nov 17, 2006 | 08:39 PM
92SleeperH23's Avatar
Default Re: rattle noise from valves problem (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Search is your best friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Your search for valve adjustment returned 939 results.</TD></TR></TABLE>
Yeah, if you search not in any particular forum, all those results for the d-series and b-series will really help
https://honda-tech.com/zerothread?id=618786
There ya go
I'll be adjusting my valves on my H23 soon
Old Nov 19, 2006 | 05:03 AM
1GPlusSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">What do you think about Mobil gas, gas guru?</TD></TR></TABLE>
It's not the top 3...I don't use it. Check cnn.com. They do research every year on the quality of fuel.
rtnlsltn
Jul 30, 2007 05:56 PM
ef-hatchcrap
15
Feb 1, 2007 04:28 PM
aut0tek
Mar 27, 2006 02:54 PM
BROKE.eg
Oct 10, 2005 07:12 AM
gsr96
Apr 3, 2003 11:32 AM
