ingalls torque damper for b series??????
i have seen these a couple times and one on a guys car but he wasn't around to ask if it was worth having. I know the B16 is a weak sauce tq. i just was thinking that this would help tighten up the front a little.....i know if i get different mounts and incerts then that will help. My B16 is all stock i just was wandering if anyone has these and like them and if they help ? thanks Dave
if you want to tighten up the front end take a look at these http://www.korbachperformance.com/framelocks.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">that helps with motor movement, not front end stiffness..
also just get an nrg one which can be had for around 50 bucks</TD></TR></TABLE>
Yeah get the NRG one. I have it and it eliminated 90% of my wheel hop. The stiffness is adjustible and you can change from rubber bushings to polyurethane bushings. It also didn't induce vibrations into the cabin like inserts and solid mounts do.
Nine
65
Feb 25, 2003 08:18 AM
