Turbo id help and need some tech ?'s answered. ****
Old Nov 13, 2006 | 11:26 AM
D15Bbigred's Avatar
Default Turbo id help and need some tech ?'s answered. ****
k the turbo i have is a t3 .42
cust p/n 748607
atd p/n 466952-5
S/N SB0414A
model # TB0356
apprently its water cooled as well. is it required to use the water cooled part? or is that an added bonus. if i do use it where do i get the fittings for it???. plus what car did this come from?
Old Nov 13, 2006 | 11:33 AM
I Have an STD's Avatar
wrenchin'
dont bother. i've used a bunch of those turbos and never water cooled them. just make sure you get a turbo timer or let the car run for 30 seconds before u turn it off.
Old Nov 13, 2006 | 12:40 PM
CRXdan's Avatar
Default Re: Turbo id help and need some tech ?'s answered. **** (D15Bbigred)
I run that turbo in non watercooled trim. Most aftermarket turbos arent watercooled so i woudlnt bother running the lines.
Old Nov 13, 2006 | 01:34 PM
b18sihatch's Avatar
if im not mistaken (dont knowe much about water cooled turbos) if you water cool them you dont need a turbo timer.
if that is the case run the water lines and be done with it, im sure you can get water lines cheaper than a turbo timer
Old Nov 13, 2006 | 02:01 PM
HamiltonRex's Avatar
Default Re: Turbo id help and need some tech ?'s answered. **** (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">
i, im sure you can get water lines cheaper than a turbo timer </TD></TR></TABLE>
yeah but whats less headaches
EJ8 GSR-T
Dec 21, 2005 09:36 PM
O16581724 5 2 5
Nov 10, 2005 10:14 AM
troubledsol03
Aug 3, 2003 06:50 PM
austrian type-R
Feb 6, 2002 08:23 PM
