sohc zc w/ z6 head
I was just curious if anyone on here has done it. The pistons from the zc should bump the the compression to 12 and if you use the y8 head gasket it should be even higher right? reply if you know anything about this setup. Is there anything I should do differently compared to the a6?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l1bid0 »</TD></TR><TR><TD CLASS="quote">I was just curious if anyone on here has done it. The pistons from the zc should bump the the compression to 12 and if you use the y8 head gasket it should be even higher right? reply if you know anything about this setup. Is there anything I should do differently compared to the a6?</TD></TR></TABLE>
The year of the sohc zc will depend if its same comp ratio or not. Either way it'll work just fine. Most of the single ZCs we deal with are same comp ratio so really exact same thing being the cam is gone anyway when you mini me it.
Just do it like a normal mini me you'll be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l1bid0 »</TD></TR><TR><TD CLASS="quote">so there's a difference between the pistons on a dohc and sohc zc?</TD></TR></TABLE>
Yes, also a difference the later sohc ZCs had a lil higher comp... ones of our years was same comp ratio.
I have done the ZC complete head with A6 bottom end. I was told by Tyson everything internally on the block was identical, with the exception of the head (cam).
With the header, I have to say, the car does perk up a bit. Nothing major mind you, but it really likes to pull from 80-up now. lotta fun. I'll still be picking up an AEM CAI and either Edelbrock IM or Y8 IM.
I've got the dohc pistions in my garage so if they're not identicle i'll just change them out. The z6 with 12:1 compression should be faster then the sohc zc right? I've spent the money on the head and p28 so i feel there's no turning back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">yes, a 12:1 comp. z6 would be a lot faster than a stock sohc zc.
just do it.
Pump gas issues?
just do it.
</TD></TR></TABLE>Pump gas issues?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Pump gas issues?</TD></TR></TABLE>
my thoughts exactly.....well?
there is a sohc thread about using the dohc pistons. When you go up that much compression you have to you premium fuel. but they didn't say anything about race gas. But i hope this swap will be satisfying. I'm doing other stuff to make it faster like fuel pressure, timming, headers, and full exhuast. So I know i'll feel the difference this spring but I'm not going to be expecting much. Its going to be fun working on everything so atleast i wont be too bored.
here's a link to the d series upgrade thread. D series bible https://honda-tech.com/zerothread?id=335078
junkyardRx
Apr 15, 2004 12:53 PM
