Coolant was changed and car overheated !!!!
I changed out my coolant and my car overheated after about 15 mintues of driving, then i recall reading about leaving air in the system. Will this cause your car to overheat?
USED DC HEADERS[CEREMIC,4-1] FOR B16a ENGINE$$$$80.00
a12rnulfo@yahoo.com
a12rnulfo@yahoo.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yjischoking »</TD></TR><TR><TD CLASS="quote">yes. very much so. bleed the air from your system when it cools back down.</TD></TR></TABLE>
yes it will.....pop you're radiator cap off and let the car run for 10-15 minutes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yjischoking »</TD></TR><TR><TD CLASS="quote">yes. very much so. bleed the air from your system when it cools back down.</TD></TR></TABLE>you can bleed it when its hot too. all the pressure from the heat will force the air(and any tiny bubbles)right out the bleed valve if you have an obd1 teg(well atleast on my 94-95 gsr).
X2 good advice fill as needed with the radiator cap off and the motor cool, run it until the thermostat hits operating temp. It will open allowing the coolant to run through and get rid of any air pockets that may be in there GOOD luck
P.s. when done don't forget to put the radiator cap back on lol
Now since my car did overheat for about 1/2 a minute to a minute before i was able to pull along side the road and let it cool, do you guy's think it caused any major internal engine damage?????
no your motor is a honda motor man you will be just fine. that short period of a time things will be just fine. i had a civic that lost all coolant and i had to drive 10mins till i could get off the freeway and it was just fine
efrex
Jul 22, 2007 03:53 PM
integlspwr2k
May 28, 2005 02:54 AM
fridexter
Nov 20, 2004 02:52 PM
