General question on Apexi VAFC 2
Old Nov 13, 2006 | 05:57 AM
Teg6's Avatar
Default General question on Apexi VAFC 2
Has anyone ever played around with a vafc 2 and it changed the rev limit? I know it's stupid and someone will write "Take it to a professional" but I don't see where I can change it. My Integra GSR hits 6521 rpm and rev limits. Also my "vtec pres" is not an option. When I click on it, it doesn't do anything. Should it? Help!!!
Old Nov 13, 2006 | 07:14 AM
be18see1's Avatar
Default Re: General question on Apexi VAFC 2 (Teg6)
its limited to 6521? is it a fuel shut off or a rev limiter?
Old Nov 13, 2006 | 07:53 AM
mugenDA9 lover's Avatar
Default Re: General question on Apexi VAFC 2 (be18see1)
i had an afc and had so many problems with it just like you. i just got rid of it and i dont think i will ever buy one again.
Old Nov 13, 2006 | 08:34 AM
no2unenolife's Avatar
double check all your initial settings.
i hope you're not fooling around w/ the a/f settings
Old Nov 14, 2006 | 04:33 PM
Teg6's Avatar
Default Re: (no2unenolife)
The setting on my vafc 2 we prest to a turbo crx with a h22 with some 450cc injectors. I am running a b18c1 with stock injectors. I kinda had to fool around with the a/f settings. My car would of ran WAYYYY lean if I didn't I mean I am figuring out the ratio crap by myself. I mean after a week I finally started to tweak it here and there. I got my lean idle fixed for the most part. I mean this damn rev limiter/fuel cut off is killing my top end. I am thinking it's not so much a fuel cut off because when I check my settings they are set up to 9000 rmp. Witch the car will only do the factory 8200. I guess my boost isn't helping either. This damn thing keeps boosting about 8lbs. I only want 5. I have one of those cheap wastegates. (Ebay) It's supposed to blow off at 5.5 but 8 lbs is just a SMIG off from that. It has two vacuum ports on it. I hooked the both up and then one at a time. One opened the valve constantly and the other by itself didn't so for now on;y the one is hooked it. This is a clusterf%%%.
Old Nov 15, 2006 | 05:37 AM
95 integra's Avatar
Default Re: (Teg6)
download the instructions from apexi-usa.com, it shows everything you need to know.
ILoveJDM.
Nov 16, 2006 05:12 PM
matix
Mar 11, 2004 09:06 AM
blackeg
Dec 23, 2003 10:46 PM
743power
Feb 6, 2003 12:20 AM
