Front end vibrates above 75mph..???
Old Nov 13, 2006 | 04:54 AM
JDM_SOHC's Avatar
Default Front end vibrates above 75mph..???
Car drives perfectly fine, until i get to 75mph i notice a slight vibration coming from the front end every couple seconds.. I just replaced tranny, axles, driver side wheel bearing, new drilled/slotted rotors w/ nice pads, new tie rods... An it still does it... I know I have some motor mount issues, but would that cause this specific problem maybe..??
Old Nov 13, 2006 | 05:36 AM
DSRxNATE DNRperformance's Avatar
Default Re: Front end vibrates above 75mph..??? (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">Car drives perfectly fine, until i get to 75mph i notice a slight vibration coming from the front end every couple seconds.. I just replaced tranny, axles, driver side wheel bearing, new drilled/slotted rotors w/ nice pads, new tie rods... An it still does it... I know I have some motor mount issues, but would that cause this specific problem maybe..??</TD></TR></TABLE>
many possibilities
-rims need to be balanced
-something is bent
-alignment is off
Old Nov 13, 2006 | 06:40 AM
instructor74's Avatar
Default Re: Front end vibrates above 75mph..??? (DSRxNATE)
I chased a similar problem on my car.After replacing everything that you did plus a few others like having all my wheels checked, replacing tires checking rotor run-out ect. I found a bad lower ball joint. It tested good until you pushed up on the bottom of the tire it would then separate about 1/4".
Old Nov 13, 2006 | 08:29 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRxNATE &raquo;</TD></TR><TR><TD CLASS="quote">
many possibilities
-something is bent
-alignment is off
rims are fine, an just had alignment... i havent hit any potholes, and it just started doing this now that i put on my new rotors an brakes... could it be they havent matched up yet or something???
Old Nov 13, 2006 | 08:30 AM
JDM_SOHC's Avatar
Default Re: Front end vibrates above 75mph..??? (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">I chased a similar problem on my car.After replacing everything that you did plus a few others like having all my wheels checked, replacing tires checking rotor run-out ect. I found a bad lower ball joint. It tested good until you pushed up on the bottom of the tire it would then separate about 1/4".</TD></TR></TABLE>
yeah good thinkin dude... i replaced one lower ball joint, but didnt feel the need to replace other.. i remember it only being like a 15 minute job, ill go get another lower ball joint an replace drivers side tomorrow an see how it handles... keep info coming, and thanks for info supplied thus far..
Old Nov 13, 2006 | 08:51 AM
fhtfhatchy's Avatar
is it constant or only under aceleration?
and your wheels are balanced?
Old Nov 13, 2006 | 09:03 AM
fmrprojects's Avatar
Default Re: (fhtfhatchy)
bad axles can cause the car to wobble also
Old Nov 13, 2006 | 09:24 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fhtfhatchy &raquo;</TD></TR><TR><TD CLASS="quote">is it constant or only under aceleration?
and your wheels are balanced?</TD></TR></TABLE>
its kinda awckward cuz it fades in and out about every 3 seconds, only while im over 75mph...
Old Nov 13, 2006 | 09:25 AM
JDM_SOHC's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">bad axles can cause the car to wobble also</TD></TR></TABLE>
both axles are brand new too...
Old Nov 13, 2006 | 01:40 PM
JDM_SOHC's Avatar
Default Re: (JDM_SOHC)
both axles are brand new too... </TD></TR></TABLE>
what else could this possibly be?
Old Nov 13, 2006 | 01:48 PM
LowSlow93Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">its kinda awckward cuz it fades in and out about every 3 seconds, only while im over 75mph...</TD></TR></TABLE>
How long does the vibration last when it is doing it?
My first thoughts are that your rims+tires are not balanced... but fading in and out doesn't really match up.
Old Nov 13, 2006 | 01:49 PM
trrbl1bmx's Avatar
Jack your car up, and put on jackstands, supporting the front of the vehicle. Now shake the tire and see what kinda of "woggy" you have! If it isn't any of the above mentioned things: then check these... INNER tie rod ends, Rack and Pinnion could be worn, Check strut rods aka radias rods, make sure ALL suspension nuts & bolts are tight. When you do all this report back. Mine had a similiar wobble but only in the excess of 70mph+ and it was inner tie rods. But I went ahead a replaced the whole rack and pinion with an ITR unit.
Old Nov 13, 2006 | 01:56 PM
JDM_SOHC's Avatar
Default Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">Jack your car up, and put on jackstands, supporting the front of the vehicle. Now shake the tire and see what kinda of "woggy" you have! If it isn't any of the above mentioned things: then check these... INNER tie rod ends, Rack and Pinnion could be worn, Check strut rods aka radias rods, make sure ALL suspension nuts & bolts are tight. When you do all this report back. Mine had a similiar wobble but only in the excess of 70mph+ and it was inner tie rods. But I went ahead a replaced the whole rack and pinion with an ITR unit.</TD></TR></TABLE>
ight dude good ****.... i thought maybe rack an pinion but havent had time to get it up on jackstands i had to come to other coast for something thats how i found out that over 75 it shakes lol... im goin home tomorrow, ill do that an let u kno wassup preciate it..
Old Nov 13, 2006 | 03:37 PM
OnePointFive's Avatar
overrated.
if it was a bent wheel he would feel it at lower speeds. Higher speed vibrations are typically and most commonly caused by an unbalanced wheel, usually do to wheel weights falling off.
Take it to a tire shop and ensure that the wheels are properly balanced
Old Nov 13, 2006 | 05:07 PM
JDM_SOHC's Avatar
Default Re: (LowSlow93Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol &raquo;</TD></TR><TR><TD CLASS="quote">
My first thoughts are that your rims+tires are not balanced... but fading in and out doesn't really match up.</TD></TR></TABLE>
it last for about 2 seconds, an happens about every 3 seconds... once under 75 it goes away...
Old Nov 13, 2006 | 05:26 PM
fhtfhatchy's Avatar
did you replace all the stuff before or after the shake? maybe its one of the new parts you put in
Old Nov 13, 2006 | 05:33 PM
ventturei27's Avatar
check your ball joints
same thing happened to me
Old Nov 13, 2006 | 07:32 PM
JDM_SOHC's Avatar
Default Re: (ventturei27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ventturei27 &raquo;</TD></TR><TR><TD CLASS="quote">check your ball joints
same thing happened to me </TD></TR></TABLE>
yeah im going to check those when i get home tomorrow i have a feeling that might be ight, because i remember while tightening my driver side LBJ it spun a little bit to much an i think i stripped it inside on accident "broken tq wrench " But yeah if thats the problem thats no biggie, i can do that in 10 minutes.. But as far as when did it occur, it just occured after i did new rotors an brakes...
Old Nov 13, 2006 | 08:52 PM
Jhonny Ricer's Avatar
a loose lug maybe?
Old Nov 13, 2006 | 09:07 PM
blackdelslo's Avatar
Default Re: (Jhonny Ricer)
Check:
1. Balance of wheels/tires (which will also rule out a bent rim.
2. Lug nuts
3. anything bent.
Old Nov 15, 2006 | 05:50 AM
JDM_SOHC's Avatar
Default Re: (blackdelslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdelslo &raquo;</TD></TR><TR><TD CLASS="quote">Check:
2. Lug nuts
3. anything bent.</TD></TR></TABLE>
Well i got to checking an as far as Tire Kingdom says, my tires are balanced right an all my lug nuts are tight... And as far as my pesonal inspection nothing looks bent to me... Also I had another question... If it was the Rack an Pinion that had gone bad, wouldnt i be able to tell by delay in the wheel?? Like if i turn my wheel an it takes a second to turn isnt that how u tell if rack n pinion is bad?
Old Nov 15, 2006 | 10:23 AM
cwf1988's Avatar
flat spots in tires
Old Nov 15, 2006 | 10:33 AM
Econo Appliance's Avatar
Default Re: (cwf1988)
bent rims
flat spot in tires or separation
warped brake rotors.
Old Nov 15, 2006 | 10:56 AM
buckin faller's Avatar
CHECK YO TYRES *****
MY WHIP DID THAT BECUZ THE TIRES
Old Nov 15, 2006 | 01:08 PM
Default Re: Front end vibrates above 75mph..??? (Stretchedandchromed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stretchedandchromed &raquo;</TD></TR><TR><TD CLASS="quote">CHECK YO TYRES *****
MY WHIP DID THAT BECUZ THE TIRES</TD></TR></TABLE>
