fitting a b16 in a 97 5 dr
Old Nov 13, 2006 | 02:53 AM
jonnycivic's Avatar
Default fitting a b16 in a 97 5 dr
please help i have a 97 civic 5 dr with a d16 engine i have bought a b16 from a 91 civic it has gearbox and ecu with it but the gearbox mounts are completly different so is the ecu conectorsd mines a obd1 and the crx 1 is obdo can i buy mounts or wiring conectors anywhere?? i have looked on hasport and cant see what i need anywhere!! i really wana fit it but dnt want cut to much about your replies will b greatley apreciated thank you!!
Old Nov 13, 2006 | 06:20 AM
igotthaspirit's Avatar
Default Re: fitting a b16 in a 97 5 dr (jonnycivic)
Im assuming by gearbox you mean Transmission. The B16 will bolt right in with stock DOHC mounts. Just use the harness out of your 97. You may have to add a VTEC controller depending on if your Civic had VTEC. By the way your 97 Civic is OBD2, just FYI.
Old Nov 14, 2006 | 02:38 AM
jonnycivic's Avatar
Default Re: fitting a b16 in a 97 5 dr (igotthaspirit)
i thought the same because of the year but i matched up the pics on the net and its an obd1 unless the pics are labeled wrong which could be the case!! so can you buy adaptors for the ecu????? the block will bolt in but the transmission is different could it be a import or something???
Old Nov 14, 2006 | 09:15 AM
gotboostedvr6's Avatar
you need to get motor mounts for B-series for the model civic you are installing this motor into such as hasport cable mounts for b-series into ek civic
92-95 ecus are the same 96-98 are the same 99-00 are the same and should not be mixed in your situation you will need 96-98 delsol Vtec P30 ecu to direct fit or you can use a 99-00 SI ecu and use a OBD 2a-b converter
BTW where are you located ?
Old Nov 14, 2006 | 02:26 PM
Default Re: fitting a b16 in a 97 5 dr (gotboostedvr6)
the last year of OBD1 was 95.
Old Nov 16, 2006 | 04:09 AM
jonnycivic's Avatar
im in england devon!! umm so cud i use my harness and just get a vtec controlor?? or do i need a new ecu?? could i deffinetly not get a adaptor for the ecu that came with the engine to go in to my car?? do you thionk that changing from cable to hydrolic clutch will be a problem??
Old Nov 16, 2006 | 11:28 AM
you can use your ecu but it will require rewiring almost every single pin. You will also have to use a Vtec controller and you may have to run a few wires to some extra sensors that you may have. You will have to add the clutch master cylinder and run the hydraulic lines for it.
Old Nov 19, 2006 | 11:48 AM
jonnycivic's Avatar
so basically i should sell it do you have any idea how much for??? is there anyway i could make my d16 non vtec fast??
Old Nov 19, 2006 | 12:09 PM
turbo it!
Old Nov 20, 2006 | 03:10 AM
jonnycivic's Avatar
so how much would this cost?? do you have any links of where i can get them???
Old Nov 20, 2006 | 08:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnycivic &raquo;</TD></TR><TR><TD CLASS="quote">so how much would this cost?? do you have any links of where i can get them???</TD></TR></TABLE>
I can build you a turbo kit for your D16. Run about $2000 with fuel management and an intercooler. Check out my site. http://www.rpmautosalon.net
Old Nov 28, 2006 | 06:29 AM
jonnycivic's Avatar
ok lets just say i keep my car and sell that engine which 1 would go in easyest or basically are none easy??? i just wana keep my car cos i love it sorry 2 b hasel guys lol
Old Nov 28, 2006 | 11:08 AM
jonnycivic's Avatar
there seem to be alot of 1.8's civic 5doors about are they more powerfull do u no how powerfull??? they dont seem very expensive either bonus
Old Nov 28, 2006 | 11:35 AM
FalkenSiR's Avatar
It looks like they speak English like **** over there in England.
Old Nov 29, 2006 | 09:23 AM
Default Re: fitting a b16 in a 97 5 dr (J.MONEY)
lol! Dude you want my opinion. You should first decide how much you are going to spend. Its gonna cost money to get that B16 up and running and its gonna cost money to go turbo too. I think you should just put a small turbo kit on that D16 roll like that. As long as you dont get carried away, you will be fine
97civic_ls
Jul 18, 2008 04:45 PM
sladed16y8
Apr 13, 2007 06:56 AM
RACEPAK
Jul 11, 2004 08:46 PM
RACEPAK
Jun 23, 2004 06:05 PM
