are LS/VTEC's reliable?
Old Nov 12, 2006 | 10:27 PM
mr nut's Avatar
Default are LS/VTEC's reliable?
i'm lookin to buy an integra with this swap. i heard bad things about them. im goin to daily drive this car. would you guys recommend gettin this car?
Old Nov 12, 2006 | 10:52 PM
Max Kling's Avatar
All depends on how it was built.
Some are and some arent, if they did it right then yes it can be reliable. Need more info on the engine.
Old Nov 12, 2006 | 11:00 PM
mr nut's Avatar
Default Re: (Max Kling)
B18B (LS) Block
Port & Polished B16 Head
CTR Pistons
CTR Cams
Crower Stainless Steel Valves
Crower Valve Springs & Retainers
JG Edelbrock Throttle Body
Walboro 255 Fuel Pump
RC Injectors
DC Headers
Injen Shortram Intake
Full Stainless Steel Custom M1 Downpipe
AEM Cam Gears
AEM Tru Power Pulleys
AEM Fuel Rail
B&M Fuel Pressure Modifier
does that help?
Old Nov 12, 2006 | 11:27 PM
fmrprojects's Avatar
Default Re: (EM1_mrnut)
you have to take the chances and believe what he syas about the motor. i alwyas like doing it myself and knoe that it was done right
Old Nov 13, 2006 | 05:41 AM
DSRxNATE DNRperformance's Avatar
dont go ctr pistons....
Old Nov 13, 2006 | 05:43 AM
HiProfile's Avatar
Unless you forgot to post eagle/crower/etc RODS in that list, then being reliable is relative. If you never take it past 7500, it should be like any other semi-built motor. The rods will want to spin the bearings, bend in half, or snap their bolts if you take it above 7500 every day.
And as fmr says, it also comes down to condition of the used items. IMO the majoriity of built blocks are piles of ****, esp if it wasn't done by a pro, and the owner is anything less than a fanatic about maintaining hit motor.
Old Nov 13, 2006 | 06:27 AM
qfast817's Avatar
Default Re: (HiProfile)
it can be if its built right and tuned
Eg_6ness
Mar 15, 2010 01:56 PM
mande456
16
Sep 10, 2008 09:45 AM
TRQLESS
Apr 1, 2007 09:28 AM
ACrite3404
Dec 1, 2006 07:20 PM
ACrite3404
Nov 5, 2006 03:02 PM
