Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
OEM fog lights installation instructions?
Old Nov 12, 2006 | 07:07 PM
mikseries's Avatar
Default OEM fog lights installation instructions?
Just got some OEM fog lights off of ebay for 06 Si. no instructions included. anyone know where i can find some online? preferably with pictures?
Old Nov 12, 2006 | 07:17 PM
TRE_'s Avatar
Default Re: OEM fog lights installation instructions? (mikseries)
http://www.handa-accessories.c...r.pdf
Old Nov 13, 2006 | 06:51 AM
mikseries's Avatar
Default Re: OEM fog lights installation instructions? (TRE_)
thanks
Old Dec 2, 2006 | 03:22 PM
cutler2start's Avatar
OK I have a question about these fog lights. I have the 2007 model si and the VSA switch is where the blank panel for the fog light switch goes in according to the directions posted above. Does anyone know the solution to this to put the switch in? Thanks in advance.
Old Dec 2, 2006 | 03:25 PM
TRE_'s Avatar
Default Re: OEM fog lights installation instructions? (cutler2start)
The on/off switch for the fogs on the 07's is integrated into the headlight / blinker combonation switch.. you will recieve a new switch for your steering column with the foglight kit.
Old Dec 3, 2006 | 05:20 PM
Fa1's Avatar
Fa1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">The on/off switch for the fogs on the 07's is integrated into the headlight / blinker combonation switch.. you will recieve a new switch for your steering column with the foglight kit.</TD></TR></TABLE>
Do you know if it's the same part as the sedan one? just curious...
Old Dec 4, 2006 | 08:16 AM
TRE_'s Avatar
Default Re: OEM fog lights installation instructions? (Fa1)
not the same
Old Dec 4, 2006 | 08:32 AM
Type X's Avatar
hey trev,
could the 07 fogs be used for the 06 ?
like for example.. i didnt want a button but i want the "new" stalk?
Old Dec 4, 2006 | 02:19 PM
TRE_'s Avatar
Default Re: OEM fog lights installation instructions? (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">hey trev,
like for example.. i didnt want a button but i want the "new" stalk? </TD></TR></TABLE>
Nope,,, that would be nice but the 06's are wired differently from the 07s
Old Jan 31, 2007 | 04:39 AM
N4me (06civicsi)'s Avatar
bumb....i have a question about my newly installed fogs the passenger side seems to be a lot brighter then the driver side could this be bad wiring or maybe the bulbs? also they seem to get very hot i saw steam rising from them.... i had a shop do it for me if anyone has seen or heard of this please let me know thnx in advance
Old Jan 31, 2007 | 04:56 AM
eL's Avatar
eL
Default Re: (N4me (06civicsi))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N4me (06civicsi) &raquo;</TD></TR><TR><TD CLASS="quote">bumb....i have a question about my newly installed fogs the passenger side seems to be a lot brighter then the driver side could this be bad wiring or maybe the bulbs? also they seem to get very hot i saw steam rising from them.... i had a shop do it for me if anyone has seen or heard of this please let me know thnx in advance</TD></TR></TABLE>
Switch the bulbs around if you think they are the problem.
Also, these fogs get extremely hot even with the OEM bulbs. They burned my laminx in 2 weeks.
Old Feb 8, 2007 | 04:50 AM
anem's Avatar
does anyone know about installation guide for euroCivic? оr where can i get it online?
Old Feb 8, 2007 | 06:13 AM
TRE_'s Avatar
It may seem brighter if its adjusted differently. There should be an adjuster screw that can be accessed from the bottom of the car and will allow you to raise/lower the beam pattern
jelyman
Jul 25, 2010 10:10 PM
SupaMonkey
Sep 16, 2008 04:07 AM
6shootahorsenamedtrigga
Acura TSX
May 31, 2006 11:32 AM
PokeyD16Z
Jan 20, 2005 03:18 PM
david90
Dec 16, 2003 12:21 PM
