post your toda or mugen header pic here
Does anyone have a dyno chart comparing the Mugen 4-1 vs Mugen 4-2-1
TIA
TIA
Thanks Bob#455
The 4-2-1 is a little better than the 4-1 all across the board, all the way up to 7600 rpm, but the 4-1 has a little more up top
Which one would you chose if you were to drag your car??? which header would have the advantage since the 4-2-1 has more power all the way up to 7600 rpm but the 4-1 has a little more kick up top???
Hybrid ctr - who edited his post so many times, because he couldn't get his question right
The 4-2-1 is significantly better than the 4-1 all across the board, all the way up to 7500 rpm, but the 4-1 has a little more up top
If the 4-2-1 makes more power up to 7,600 RPMs, one could logically assume that it will out-accelerate the 4-1 up to 7,600 RPMs...and if it gets to that point sooner, it will hit redline sooner too because the 4-1 won't have enough time (7,600 RPMs to 8,400 RPMs) to make up the difference. I vote for the 4-2-1...
read the question I added to my post above, it's like you read my mind
It's hard to determine which you would really want, but I think the 4-2-1 has the slight advantage too
