How to get rid of the check engine light?
Old Nov 12, 2006 | 06:07 PM
rsxtacyy's Avatar
Default How to get rid of the check engine light?
how can i get rid of the check engine light since i have a test pipe i tried buyin one of those sensor mods that u splice into your o2 sensor
Old Nov 12, 2006 | 06:32 PM
cnyej1's Avatar
Default Re: How to get rid of the check engine light? (acurtayy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurtayy &raquo;</TD></TR><TR><TD CLASS="quote">how can i get rid of the check engine light since i have a test pipe i tried buyin one of those sensor mods that u splice into your o2 sensor</TD></TR></TABLE>
What do you mean you "tried" buying one of those sensors? Eithe use one of "those" Sensors, or use the DIY mechanical 02 sim.
Your basically spacing the o2 sensor from the actual exhaust pipe.
Old Nov 13, 2006 | 10:06 AM
rsxtacyy's Avatar
Default Re: How to get rid of the check engine light? (cnyej1)
the 02 simulator didnt work
Old Nov 13, 2006 | 01:26 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurtayy &raquo;</TD></TR><TR><TD CLASS="quote">the 02 simulator didnt work</TD></TR></TABLE>
Then you did it wrong. Either that or the actual sim is faulty.
Old Nov 13, 2006 | 02:49 PM
rsxtacyy's Avatar
hm well thats a pain in the *** i just havent messed with it since cuz i havent had time...where do you recommend me getting one ?
Old Nov 13, 2006 | 03:04 PM
cnyej1's Avatar
Default Re: How to get rid of the check engine light? (rsxtacyy)
This is not my DIY, this was taken off of EPhatch
Here you go:
CEL Problems - Mechanical 02 Sim
Available at your local automotive store. Spark Plug Non Fouler PN 42009 ($4.99)
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
Side by Side comparision of the orignal and now modified non foulers
o2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler
Original non fouler-&gt;Modified non fouler-&gt;o2 sensor
Fully installed
By moving the secondary o2 sensor away from the direct path of exhaust flow and limiting what exhaust gas can get to the o2 sensor the ecu believes that there is a functioning cat still in the system.
I have confirmed that this works on our vehicles. I installed this piece at 18900 miles with a reset ecu and I now have 24000 on the clock with no CEL.
Old Nov 13, 2006 | 03:35 PM
rsxtacyy's Avatar
thanks man i appreciate it
Old Nov 13, 2006 | 03:36 PM
rsxtacyy's Avatar
so i need to do this to the second 02 sensor?
Old Nov 13, 2006 | 03:41 PM
cnyej1's Avatar
Yes just the second one.
Old Nov 14, 2006 | 05:50 PM
rsxtacyy's Avatar
drilling that damn non fouler was a huge bitch i tried several different drill bits and even a whiz wheel but it kept getting so hot it would start to melt the drill bits
Old Nov 14, 2006 | 05:58 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxtacyy &raquo;</TD></TR><TR><TD CLASS="quote">drilling that damn non fouler was a huge bitch i tried several different drill bits and even a whiz wheel but it kept getting so hot it would start to melt the drill bits</TD></TR></TABLE>
Hahaha......did you get bits made to drill metal? Probably not. Go over to SEARS and ask for a carbide tip drillbit.
Old Nov 15, 2006 | 04:41 AM
RSXTYPES0818's Avatar
question about the test pipe i want to get one but people say that it makes ur car sound like **** is that true and when it is on can u actually feel a little more power or not
Old Nov 15, 2006 | 05:53 AM
cnyej1's Avatar
Default Re: How to get rid of the check engine light? (RSXTYPES0818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSXTYPES0818 &raquo;</TD></TR><TR><TD CLASS="quote">question about the test pipe i want to get one but people say that it makes ur car sound like **** is that true and when it is on can u actually feel a little more power or not</TD></TR></TABLE>
Having this done makes a night and day difference. It all depends on what exhaust you have for sound quality.
Old Nov 15, 2006 | 09:03 AM
i have skunk 2 exhaust with megan headers with that effect the sound and if i wanted to get a test pipe which type should i get
Old Nov 15, 2006 | 01:21 PM
rsxtacyy's Avatar
ha yeah i did actually but those damn non foulers are made to withstand all the heat the spark plugs take on so theyre a bitch to drill
Old Nov 15, 2006 | 01:26 PM
rsxtacyy's Avatar
no way man it sounds nice ive got a dc sports header with a megan test pipe and am getting a greddy exhaust but i think its more up to the exhaust you get on the sound and yes the test pipe made a good difference you can tell a lot just standing behind the car and feeling the exhaust from ab 5 feet away
Old Nov 16, 2006 | 01:34 PM
rsxtacyy's Avatar
the non fouler idea was close but no cigar...there wasnt room for two foulers so i put the senser just in the drilled fouler and i guess it wasnt offset enough from the exhaust flow not to trip the check engine light...it worked for about a night so i tried to put them on the first senser just for ***** to see if it would make any difference and it wouldnt even fit in the non fouler, thanks for the help tho im tryin everything for this damn thing
Old Nov 16, 2006 | 06:55 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxtacyy &raquo;</TD></TR><TR><TD CLASS="quote">the non fouler idea was close but no cigar...there wasnt room for two foulers so i put the senser just in the drilled fouler and i guess it wasnt offset enough from the exhaust flow not to trip the check engine light...it worked for about a night so i tried to put them on the first senser just for ***** to see if it would make any difference and it wouldnt even fit in the non fouler, thanks for the help tho im tryin everything for this damn thing</TD></TR></TABLE>
Seriously they will fit......there have been many many people before yo that have done this and they all fit fine.
Old Nov 16, 2006 | 08:55 PM
97 Sleeper's Avatar
yup my friend did it on his MSP and it works just fine
01SSAP1
Honda S2000
Sep 4, 2007 09:04 AM
civicsaremean
Jun 24, 2007 08:27 AM
matt6187
Jun 10, 2007 04:58 PM
J.nguyen
Mar 19, 2006 10:07 PM
Spazzua15
Dec 14, 2005 06:21 PM
