ignition
Old May 7, 2002 | 06:49 PM
imported204's Avatar
Default ignition
when i start my car it makes that buzzing noise, like when the car is started and u accidently try to start it again. This happens for abut a second when i turn on the ignition, does anyone know what it could be? Sorry if it is a little vague but its the best i can explain it.
Old May 7, 2002 | 07:11 PM
...me0w's Avatar
Default Re: ignition (imported204)
i ocassionally run into the same problem but i have also done a manual to 5 speed conversion in my car so that is what causes mine to do that in your case i would have to ask how long after the car turns over do you still hold the key over to start the car.
Old May 7, 2002 | 07:23 PM
JG Luder's Avatar
My first thought is the starter is going bad.
Old May 7, 2002 | 07:24 PM
Default Re: ignition (JG Luder)
i just had the ignition control module replaced too
Old May 8, 2002 | 04:45 AM
Anubyss's Avatar
I have that problem once in a while as well. I thought it was due to my Fidanza flywheel. Do you guys have a lightened flywheel? I guess I should try replacing the starter and see if that resolves the situation.
Old May 8, 2002 | 03:22 PM
Default Re: ignition (Anubyss)
my car is completely stock
DC4 Rasta
Aug 29, 2007 07:03 PM
inane
Apr 20, 2005 05:52 PM
92TEGsrSC
Jun 18, 2003 09:15 PM
skrewdlude
Jun 4, 2003 05:12 PM
