ignition
when i start my car it makes that buzzing noise, like when the car is started and u accidently try to start it again. This happens for abut a second when i turn on the ignition, does anyone know what it could be? Sorry if it is a little vague but its the best i can explain it.
i ocassionally run into the same problem but i have also done a manual to 5 speed conversion in my car so that is what causes mine to do that in your case i would have to ask how long after the car turns over do you still hold the key over to start the car.
I have that problem once in a while as well. I thought it was due to my Fidanza flywheel. Do you guys have a lightened flywheel? I guess I should try replacing the starter and see if that resolves the situation.
DC4 Rasta
Aug 29, 2007 07:03 PM
inane
Apr 20, 2005 05:52 PM
