input shaft has 1/8" play in it, what is needed to fix it.
Old Nov 12, 2006 | 05:41 PM
si90rex's Avatar
Default input shaft has 1/8" play in it, what is needed to fix it.
the tranny is a Y1 lsd. the input shaft moves in and out 1/8" when it was in the car it knocked when u turned a corner. i know the noise is from the tranny, cause i swapped them out but i want my lsd tranny. i just need to know what parts are needed. i'll get them from gear speed.
thanks
Old Jul 23, 2015 | 12:06 AM
avotegra's Avatar
Default Re: input shaft has 1/8" play in it, what is needed to fix it.
What did u do to fix the play.
Old Jul 24, 2015 | 02:33 PM
jonGSR's Avatar
Have you pulled apart the transmission? Possibly the input shaft bearing and seal. I repaired a damaged HF transmission but the input shaft would move side to side, not in and out. I replaced those 2 parts and it fixed it.
xseekanddestroyx
Aug 22, 2007 07:37 PM
B18C Turbo
Oct 3, 2006 02:11 PM
DEMNTD1
Aug 12, 2005 11:12 AM
Kusai.Nihonjin.Desu
Oct 27, 2003 09:54 PM
Pengo
Jun 20, 2003 08:52 PM
