SH suspension upgrade ?
Old Nov 12, 2006 | 01:25 PM
kadidle's Avatar
Default SH suspension upgrade ?
i have a 1999 prludee sh and everywhere i look i can find any struts/shocks for my sh. does anyone have a idea of where i can buy any for my sh and what brand ?
Old Nov 12, 2006 | 02:40 PM
vinuneuro's Avatar
Default Re: SH suspension upgrade ? (kadidle)
As long as you change the springs too, you can use any shock available for the base.
Old Nov 12, 2006 | 03:03 PM
kadidle's Avatar
Default Re: SH suspension upgrade ? (vinuneuro)
then why do they say they wont fit SH models ?
Old Nov 12, 2006 | 04:11 PM
honda_andy's Avatar
cuz the springs are wound tighter on the sh i believe. and they will only fit on the stock shocks, if you have shocks AND struts made for a base, they will work on the sh.
Old Nov 12, 2006 | 04:18 PM
ghost SHell's Avatar
Try NOPI online store. That's where I got my Tokico Illumina 5-way adj. for my SH.
Old Nov 12, 2006 | 04:31 PM
vinuneuro's Avatar
Default Re: (honda_andy)
The springs aren't wound tighter. The SH springs are slightly longer.
Old Nov 12, 2006 | 04:56 PM
kadidle's Avatar
Default Re: (vinuneuro)
so basically as long as i have upgraded springs and shocks im fine ?
Old Nov 12, 2006 | 04:59 PM
kadidle's Avatar
Default Re: (kadidle)
by the way are tokico and koni shocks much different ppl say that koni yellows are the best
Old Nov 12, 2006 | 05:34 PM
E-Money's Avatar
you get what you pay for
Old Nov 14, 2006 | 02:43 PM
kadidle's Avatar
Default Re: (E-Money)
is it better to go with koni and GC or just get like tein coil overs
Old Nov 14, 2006 | 02:48 PM
AndyD's Avatar
I am not sure what the difference between the Base and Type SH rear suspension is, but make sure you can use them before buying.
I recommend KYB AGX/GC coilover sleeve combo. Best for the money. I have TEIN Basics and I am not happy with them. Very harsh and they feel like they bottomout too easily.
Old Nov 15, 2006 | 06:18 PM
kadidle's Avatar
Default Re: (AndyD)
are tokico illuminas or koni worth it ?
Old Nov 15, 2006 | 07:30 PM
JDMludechik's Avatar
A simple Koni setup is very much worth it. The front suspension on the Sh model is made for a progressive rate spring. Honda did this to compensate for the little bit of understeer that was associated with the atts unit. When buying suspension, the best way to go would be buying a complete spring/shock combo for the base model since not to many companies make a direct SH application. Or you could simply buy BB6 coilovers and call it a day.
patkim333
Nov 6, 2007 10:54 AM
roflcopterdown
Sep 9, 2007 05:55 PM
honda_andy
Jun 20, 2006 02:35 PM
dj626
Sep 7, 2004 12:52 PM
jeffe
Mar 7, 2003 11:47 PM
