itr dual valve springs & ret. vs After market???
Old Nov 12, 2006 | 09:34 AM
ProjectBoosted's Avatar
Default itr dual valve springs & ret. vs After market???
i have an itr head wth the stock valve train which i plan on using for my 600 whp turbo build. I was wondering if the stock itr dual valve springs & ret. were good enough to rev up to 9500? if not what kind will give me the best bang for my buck? I do not want to go cheap i just dont want to go all out on these parts, If it matters, I will be running stock itr cams. thanks for any help, please post links to sites that you may recommend.
Old Nov 12, 2006 | 09:40 AM
BoostedEG6's Avatar
Default Re: itr dual valve springs & ret. vs After market??? (ProjectBoosted)
supertech springs and retainers
Contact EARL for prices
Old Nov 12, 2006 | 09:55 AM
Jared's Avatar
you're gonna need some more seat pressure, plus the itr retainers crack if you rev them that high for too long.
Old Nov 12, 2006 | 05:34 PM
I'm new to this site and i know this is going to sound stupid but how do i contact earl?
Old Nov 12, 2006 | 08:12 PM
dmotoguy's Avatar
http://www.laskeyracing.com/shop/shop.htm
Old Nov 12, 2006 | 11:06 PM
namm's Avatar
You must change your retainers as jared said, you can get crower retainers. For springs the cheapest way is to use portflow inner valve springs with your type R outers. This is good for 9500 easy. I have used this set up succesfully with toda spec B cams which have more lift and duration than the ITR that your using
Old Jun 19, 2008 | 12:49 PM
dmotoguy's Avatar
Default Re: itr dual valve springs & ret. vs After market??? (namm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by namm &raquo;</TD></TR><TR><TD CLASS="quote">You must change your retainers as jared said, you can get crower retainers. For springs the cheapest way is to use portflow inner valve springs with your type R outers. This is good for 9500 easy. I have used this set up succesfully with toda spec B cams which have more lift and duration than the ITR that your using</TD></TR></TABLE>
so portflow inners, type r outers and crower retainers? or itr retainers?
dc4teg95
Nov 16, 2007 12:01 PM
Baron55
Jan 15, 2007 04:57 PM
roadawg
Jan 27, 2004 01:48 PM
Patch
Feb 6, 2003 02:26 PM
