auto power window switch in del sol
I would like to convert the rear and passenger side power window switches to auto down switches like the drivers door window. Would it be as simple as purchasing the oem switch for the drivers side window and swapping them out?
http://www.directed.com part # 530t automation up and down
Thanks for trying. But the site doesn't work. Once on the site I entered the item number which produced several items which none will load up.
thanks for the link. However that kit only operates 2 windows.
I'm really just looking to convert the stock switches to auto down by touch.
So the original question is still out there. Can I just swap out the pass and rear window switches with drivers side units and have all window be auto down?
well you can wire that module up on the pass, and rear window and they will be auto down. but no you cant replace your switches, the auto down feature is built into the power window/lock module that is usually mounted in the door in a civic, it might be the same place in a del sol.
Do you really think I can wire all three window into the one module or should I buy a seperate one for each window? Not that I know what it looks like but just asking.
You said power lock module. Are you talking about the lockout switch for the windows I have on the drivers side window controls for the passenger windows?
kchungb17a
Feb 15, 2010 07:57 AM
david90
May 29, 2004 04:22 AM
