first rebuild.. Rod bearings
Old Nov 12, 2006 | 03:45 AM
ej2civic's Avatar
Default first rebuild.. Rod bearings
OK, So this is my first re-build..
I need to know what rod bearing to choose.
Engine is jdm B16A, it has about 100-120tkm.
Old bearings are green...
So should I just get NEW green ones?
One pic..
Old Nov 12, 2006 | 05:59 AM
Duane_in_Japan's Avatar
Default Re: first rebuild.. Rod bearings (ej2civic)
sorry its been years since I got to do an engine up, too much money where I live now. I didnt know they came in colors but I know the come in sizes, standard if you are not going to turn the crankshaft and I guess that STD will be green then, can you show a pic of both halves of the bearings to show us the wear pattern please and there should be part number info on the back also, that is for you though.
Old Nov 12, 2006 | 07:03 PM
93lsd's Avatar
if they are green i would go with the acl race bearing, the acl bearings are standard green bearings
Old Nov 13, 2006 | 06:29 AM
mmuller's Avatar
Mad Scientist
Default Re: (93lsd)
even though they are green by the charts i would still check clearances
But if they are would go for acl's also. If money is not an issue then maybe mix of oem b-series and k series
Old Nov 14, 2006 | 06:01 AM
ej2civic's Avatar
Default Re: (mmuller)
I think no one in Finland sells those
So Ill take the oem green ones, but thanks
djrichb20t
Mar 5, 2017 01:12 PM
amadriga
Feb 12, 2008 04:27 AM
TypeRbuild718
Jun 25, 2007 07:07 PM
marcussmith26
Jan 17, 2006 02:45 PM
Dee
Mar 7, 2002 08:01 PM
