my lsvtec turbo set up . 295whp / 199tq.. hella weak
Old Nov 12, 2006 | 12:53 AM
gsp ej1-em1's Avatar
Default my lsvtec turbo set up . 295whp / 199tq.. hella weak
lsvtec.
81.5mm bore
wiseco pistons
eagle rods.
gsr cams
Portflow head
GT30r 60trim.
RC 750 injectors.
Blox intake manifold.
Revhard log type manifold.
3inch dp
Crome Engine Management. * edited * didn't know i spelled crome wrong.
and some other crap.
didn't make the power i wanted. I'm planning on boosting 15lbs. we'll see how that goes.
295whp / 199tq @ 11lbs.
to dnr performance for tuning my car.
Modified by GSP EJ1 at 11:14 AM 11/12/2006
Modified by GSP EJ1 at 12:12 AM 11/13/2006
Old Nov 12, 2006 | 01:05 AM
chris408's Avatar
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (GSP EJ1)
congrats!
Old Nov 12, 2006 | 01:24 AM
komat's Avatar
i wouldnt go more then what you have now unless its forge internals. the tq seem a little low too
Old Nov 12, 2006 | 01:37 AM
quik sol's Avatar
bump her to 350hp and call it a day...
Old Nov 12, 2006 | 02:44 AM
SL0WEGG's Avatar
Default Re: (quik sol)
I think i know why its hella weak. I hear cHrome doesnt work too well for an ems
Old Nov 12, 2006 | 03:36 AM
Danny_EJ's Avatar
that tq is really low for an ls crank.. at the same hp level i was around 230wtq on a dyno jet
Old Nov 12, 2006 | 05:00 AM
blackeg's Avatar
is your timing really really conservative? that could be a reason why both power and tq are lower than you expected. im willing to ssay that even if you are a degree or so retarded in timing it will make the noticeable difference (so long as you arent already at mbt)
Old Nov 12, 2006 | 06:25 AM
DaveF's Avatar
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (blackeg)
i think the power is down like 30hp at least.
what exhuast sytem is on the car ?
Old Nov 12, 2006 | 06:41 AM
. a d a m's Avatar
You aren't running open wg are you?
Old Nov 12, 2006 | 10:14 AM
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (. a d a m)
open wg? whats that mean? i got a ghetto *** boost controller. getting a ebc this week and going back to the dyno.
Old Nov 12, 2006 | 10:20 AM
alpha's Avatar
Doesnt look too bad. Where is your wastegate dumping?
<Edit>
Looks like your making 11lbs / full boost late
</Edit>
urbansi's Avatar
He is asking if there is a dump tube coming off of your wastegate that is directed behind the oil pan, or somewhere around that area, open wastegates are a huge power killer due to exhaust gases being scavenged back threw the turbo
Modified by urbansi at 3:59 PM 11/12/2006
Old Nov 12, 2006 | 11:46 AM
. a d a m's Avatar
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">He is asking if there is a dump tube coming off of your wastegate that is directed behind the oil pan, or somewhere around that area, open wastegates are a huge power killer due to exhaust gases being scavenged back through the turbo</TD></TR></TABLE>
Old Nov 12, 2006 | 01:26 PM
boosted k20's Avatar
looks like wastegate dump issues from that dyno graph. curve looks good up to 6.4K rpms... def. put a dump tube routed under the oil pan if u dont have one already
Old Nov 12, 2006 | 02:24 PM
JDMisGOOD's Avatar
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (boosted k20)
What c/r of the pistons?
Old Nov 12, 2006 | 02:42 PM
nah my dumptube goes under the car. too the tranny side. my c/r is estimated at low 9:1.
Old Nov 12, 2006 | 03:11 PM
Timmay's Avatar
Default Re: (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">I think i know why its hella weak. I hear cHrome doesnt work too well for an ems</TD></TR></TABLE>
i think you hear wrong.. ive seen plenty of 9/10/11 second cars on crome with no problems
for 11 lbs the #'s seem a little low.. probably really conservative timing
Old Nov 12, 2006 | 03:27 PM
TurboJesse
Guest
Posts: n/a
put a good manifold and theres your extra 30-40whp...
I don't know about you but i wouldn't expect much more with that setup at 11lbs..
I tuned a similar setup (81.5mm bore, same compression, portflow head, gt30r, but with tubular manifold) on crome and it made 371@10psi..
Old Nov 12, 2006 | 03:35 PM
Timmay's Avatar
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (TurboJesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse &raquo;</TD></TR><TR><TD CLASS="quote">put a good manifold and theres your extra 30-40whp...
I tuned a similar setup (81.5mm bore, same compression, portflow head, gt30r, but with tubular manifold) on crome and it made 371@10psi..</TD></TR></TABLE>
yea those numbers would sound alot better.. we did a stock gsr with drag manifold and ebay 57 trim on 10lbs did 303 with crome.. and it was still pretty conservative.. thats why i was thinking his may be a bit to conservative or something..
Old Nov 12, 2006 | 03:44 PM
TurboJesse
Guest
Posts: n/a
Default Re: my lsvtec turbo set up . 295whp / 199tq.. hella weak (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">
yea those numbers would sound alot better.. we did a stock gsr with drag manifold and ebay 57 trim on 10lbs did 303 with crome.. and it was still pretty conservative.. thats why i was thinking his may be a bit to conservative or something..</TD></TR></TABLE>
who knows....then again every dyno is different
Old Nov 12, 2006 | 03:51 PM
Timmay's Avatar
who knows....then again every dyno is different </TD></TR></TABLE>
yea i was just thinking about that lol
our #'s were on dynojet to but there are still alot of factors that make a difference
Old Nov 12, 2006 | 04:59 PM
Jim Truett's Avatar
Default Re: (Timmay)
for 11 lbs the #'s seem a little low.. probably really conservative timing</TD></TR></TABLE>
Re-read his post very carefully.
Old Nov 12, 2006 | 05:11 PM
werd.
u have a pretty good turbo but ur manifold aint the best.
also do u know how much timing they ran in that motor?
Old Nov 12, 2006 | 05:22 PM
im going to redyno on friday. we'll see how it goes. DNR didn't push it all the way. no point in tuning it for hours on end if i couldnt get the boost i wanted.
Old Nov 12, 2006 | 06:09 PM
turboekcivic's Avatar
