Installing an aftermarket CD player in an EK DX
Old Nov 11, 2006 | 10:08 PM
LShatchboy's Avatar
Default Installing an aftermarket CD player in an EK DX
I tried to search this out, but everything seemed to general to be of much help. I recently purchaced an EK DX hatchback and I want to put my new Alipine deck in it but am having some slight issues and have a few questions. First of all, what is the easiest way to go about removing the factory radio? Once out, what will I need to install the deck and make it look right? The reason I ask is because the way the dash is shaped on the drivers side, it is angled slightly and so is the factory radio to match, but my alpine obviously isnt.
Just looking for some help before I tear into it tomorrow,
thanks
-Marc
Oh, are the factory rado's worth anything?
Old Nov 11, 2006 | 10:18 PM
Eran's Avatar
HT White Ops
Aparently you have a 96-98.
First, to match the curve, you're going to have to get a trim kit. Also, for the best plug/play alternative (and easiest wiring), buy a harness adapter. You can find both of these by selecting your vehicle on http://www.crutchfield.com
Also, another option is installing the new deck where the pocket behind your cupholders are, and keeping your stock deck in it's stock location. This will deter theft if you take your faceplate off and leave your cupholder lid up, making it look like you have just a stock radio.
To get your stock radio out, you are going to need to take off your knee bolster pannel, your 12v accessory pannel, and your glovebox. Then you get up under there with a philips head screwdriver and unscrew the two screws on a bracket way back in the dash. It's not picknick, I'll tell you that.
Also, no, your stock radio isn't worth much. I'm selling a spare for $15.
Old Nov 11, 2006 | 10:37 PM
pdiggitydogg's Avatar
yeah, sounds like 96-98 from the radio shape
http://www.installdr.com/Insta...3.pdf
you need a plastic install kit to fit that odd shaped hole
Old Nov 11, 2006 | 10:43 PM
LShatchboy's Avatar
wow, thanks for the help! And yes, the car is a 1996... I wasnt aware that the 98-00 were that much different.
Old Nov 11, 2006 | 10:46 PM
99-00
Radio and climate controls are quite different
have fun with the install
Old Nov 11, 2006 | 10:51 PM
Eran's Avatar
HT White Ops
I really do reccomend keeping your stock deck up top. It will deter walk-by breakin's from meth-heads just looking for a quick score. Also, when your deck is down below, it's bolted in as well, instead of just sliding it into a metal cage that it can be pulled out of in about 5 seconds.
Here's my setup with working stock deck and stock CD slave. Used to have an Eclipse deck, but I wanted something a little cleaner.
Old Nov 11, 2006 | 10:55 PM
we dont have that EL center console here....Id love one for my car.........
Old Nov 11, 2006 | 10:59 PM
Eran's Avatar
HT White Ops
Default Re: (pdiggitydogg)
I'm from the US too. If it was a real EL, it'd have a different climate control I bought it from someone who does live in teh Canadas.
Old Nov 11, 2006 | 11:00 PM
what did you pay for it?
its my experience that canadian parts are ridiculously priced compared to US counterparts
Old Nov 11, 2006 | 11:18 PM
Eran's Avatar
HT White Ops
$170 shipped for the audio console, pocket, and entire shifter/cupholder console.
Old Nov 12, 2006 | 01:28 AM
Thizzed Out's Avatar
Default Re: (Eran)
damn thats a clean car . I've never seen that stock CDplayer in that place b4..is that the piece ur saying that u got from canada? and whats that square button above the a/c number 4 for?
Old Nov 12, 2006 | 03:46 AM
Duane_in_Japan's Avatar
Default Re: (Eran)
Those heavy keys are going to kill your ignition switch there Gus. FWIW.
Old Nov 12, 2006 | 08:52 AM
GG99's Avatar
eran do you think u could post up some clearer pics of the EL console? ive never seen it before.
Old Nov 12, 2006 | 09:53 AM
Eran's Avatar
HT White Ops
Default Re: (GG99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GG99 &raquo;</TD></TR><TR><TD CLASS="quote">eran do you think u could post up some clearer pics of the EL console? ive never seen it before.</TD></TR></TABLE>
Old Nov 12, 2006 | 10:27 AM
EJAYATE's Avatar
I Deliver
Wow I need one of those. I got my deck where my tape deck was, but I dont like trying to change songs, ect. while a beverage is occupying my cup holder. Such a pain in the ***. I do like to leave my cup holder up to prevent theft but my sparco pro2k kinda f'ed that up.
Default Re: (Eran)
that iish is niceeee..even the shifter box is diff.
Old Nov 12, 2006 | 09:19 PM
GG99's Avatar
Default Re: (Eran)
thanks homeboi
Old Nov 12, 2006 | 09:48 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (GG99)
the EL console looks nice, but what do you get over the stock console? The stock console already has a second radio spot and a security flap to go with it? Also did any stock 96-98 head unit come with a cd player?
Old Nov 12, 2006 | 09:56 PM
Eran's Avatar
HT White Ops
Default Re: (cbmprelude)
I don't get anything but a better looking console.
And no, no 96-98 civic radio came with an integrated cd player (at least stateside). The 1.6 EL had a radio identical to the 99-00 si cd player, except it said ACURA instead of HONDA at the top. The lower din was reserved for a pocket or a cassete slave.
Old Nov 13, 2006 | 02:15 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Eran)
was there ever an oem option to add a single cd to the bottom lot and have it controled through the oem headunit uptop?
Ramcharger310
Audio / Security / Video
Jun 17, 2016 04:56 PM
Frost7177
Apr 16, 2009 09:13 PM
99lspwr
Feb 15, 2008 05:41 AM
emjaycee21
Aug 16, 2007 12:15 PM
batmanek9
Mar 31, 2004 06:44 PM
