What kind a brake pads can I use...
Old Nov 11, 2006 | 06:25 PM
dubs97integ's Avatar
Default What kind a brake pads can I use...
Hey whats up guys, I need some help. I just purchased a 96 spec 4x114 brake conversion and I need to get some new brake pads. I did do the research and I did hear that ANY DC pads would work. BUT still a bit unsure. Any help will be appreciated. Thanks in advance.
Old Nov 11, 2006 | 11:02 PM
ZygSpeed's Avatar
Default Re: What kind a brake pads can I use... (dubs97integ)
Possibly something for/from a GSR teg.
Check the rotor diameter.
Call an aftermarket brake place like StopTech or Cobalt Friction.
http://www.cobaltfriction.com/
Old Nov 11, 2006 | 11:27 PM
92TypeR's Avatar
FSAE
Default Re: What kind a brake pads can I use... (zygspeed)
I believe they are the same size caliper and rotor as 94-01 GSR/LS/GS/RS
Old Nov 12, 2006 | 01:50 AM
tartje's Avatar
no, not all pads will fit
96 spec brakes 262mm
98 spec brakes 282mm
make sure you get the right ones
Old Nov 12, 2006 | 07:51 AM
Default Re: What kind a brake pads can I use... (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Possibly something for/from a GSR teg.
http://www.cobaltfriction.com/</TD></TR></TABLE>
Thats another thing I heard was the GSR ones would work for me. But I will call around, Thanks
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I believe they are the same size caliper and rotor as 94-01 GSR/LS/GS/RS</TD></TR></TABLE>
They kinda look about the right size, I havent compared them side to side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">no, not all pads will fit
make sure you get the right ones </TD></TR></TABLE>
Thanks everyone, anybody else know for sure?
Old Nov 19, 2006 | 11:38 PM
Any body got other suggestions? i don't have time to call around in daytime.
Old Nov 19, 2006 | 11:57 PM
tartje's Avatar
after a brief search here and finding the stickied thread on the UK DC2 forum:
http://www.itr-dc2.com/forum/viewtopic.php?t=19058
YES GS-R pad size fits on the '96 spec JDM brakes which shares the fitment of 4.114.3 262mm
HTH
Old Nov 20, 2006 | 04:40 PM
mugenracer's Avatar
HTH </TD></TR></TABLE>
Close...GSR's use 4x100 PCD discs, but you are right front and rear GSR pads are the same as 96psec ITRs.
Old Nov 21, 2006 | 10:40 AM
Default Re: What kind a brake pads can I use... (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">Close...GSR's use 4x100 PCD discs, but you are right front and rear GSR pads are the same as 96psec ITRs.</TD></TR></TABLE>
Ok, cool, GSR pads. Now any suggestions on some pads that aint too pricey?
Thanks for all the help everyone
Old Nov 21, 2006 | 10:45 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubs97integ &raquo;</TD></TR><TR><TD CLASS="quote">Ok, cool, GSR pads. Now any suggestions on some pads that aint too pricey?
Thanks for all the help everyone </TD></TR></TABLE>
ahem...you have PM
Old Nov 21, 2006 | 10:48 AM
tartje's Avatar
i apologise and stand corrected
Default Re: What kind a brake pads can I use... (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">ahem...you have PM </TD></TR></TABLE>
Pm'ed you back
zakarylakota
Dec 30, 2018 06:12 PM
Fatcobra
Mar 27, 2007 11:45 AM
CDN Yellow ITR
Jul 16, 2004 05:47 PM
FastNFurious
Mar 6, 2004 06:08 AM
Fooman
Nov 26, 2001 09:26 AM
