if you have the oil at the low end of the dipstick will you get better mileage?
Old Nov 11, 2006 | 05:47 PM
piggydog's Avatar
Default if you have the oil at the low end of the dipstick will you get better mileage?
? I said yes, very small but yes. My friend says it doesn't matter
Old Nov 11, 2006 | 06:08 PM
darkspector2.0's Avatar
OMG... I would rather go through a little more gas than starve my engine of oil....
Old Nov 11, 2006 | 06:14 PM
~sp33~'s Avatar
EFB055
Default Re: (darkspector2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">OMG... I would rather go through a little more gas than starve my engine of oil....</TD></TR></TABLE>
Having no oil in your engine will cost you more in the long run.
Old Nov 11, 2006 | 06:23 PM
98vtec's Avatar
moderator emeritus
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (piggydog)
i'd like to know why you would think having less oil would net better gas mileage.......
Old Nov 11, 2006 | 06:34 PM
asdfsad's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (98vtec)
Less weight? lol if you really are that concerened with your MPG, do the simple things are just re-evalaute how you drive and make sure your car has had its tune ups.
Old Nov 11, 2006 | 06:36 PM
M2B4's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (asdfsad)
...and if your really really concerned about mpg go buy a honda insight
i aswell would like to know why less oil increases mpg
Old Nov 11, 2006 | 06:40 PM
The_Head's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (M2B4)
I'm going to say less oil means less oil sticking to the rotating assembly, which leads to less friction and more MPG...
Even if that were the case, I wouldn't do it.
Old Nov 11, 2006 | 06:48 PM
M2B4's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (The_Head)
oh i would assume if there was less oil then there would be more friction since the oil is a lubricant that keeps things moving freely, but i could be wrong.
Old Nov 11, 2006 | 06:50 PM
The_Head's Avatar
Well if the oil is riding along on the crank counterweights and other non bearing surfaces, then it would add more resistance methinks.
Old Nov 11, 2006 | 06:52 PM
M2B4's Avatar
mabye, but i would think opposite since its a lubricant which would make it rotate easier, but im not sure so mabye your right mabye i am who cares lol
Old Nov 11, 2006 | 06:56 PM
98vtec's Avatar
moderator emeritus
less oil = frictional parasitic losses while the piston travels up and down the bore, not to mention an engine running hotter due to the friction.
IMO
Old Nov 11, 2006 | 07:03 PM
Revi's Avatar
NO OIL= NO VTEC
NO VTEC = PSLOW
PSLOW = BETTER MPG
Old Nov 11, 2006 | 07:39 PM
shutta's Avatar
there we go, problem solved..
Old Nov 12, 2006 | 01:07 AM
Charliegrs's Avatar
yes the added friction of having less oil in the engine will greatly increase your gas mileage.
oh and throw some sand in the motor while your at it, that will be better than having like a hybrid
Old Nov 12, 2006 | 02:30 AM
Apex1972's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (Charliegrs)
just use the 0W40 synthetic for the hybrids and see how that does.
Old Nov 12, 2006 | 02:47 AM
if you're really that concened, get your rotating assembly balanced and crank knife edged... that will get rid of unecessary stress and cause less windage... freeing up power and making your motor more effecient. Do any cars come with knife edged cranks?
Old Nov 12, 2006 | 02:21 PM
lude98SH's Avatar
http://www.drysump.com/drysump.htm
Old Nov 12, 2006 | 02:45 PM
Rosko's Avatar
Default Re: if you have the oil at the low end of the dipstick will you get better mileage? (lude98SH)
I know of some old prostock racres who used to drain there oil before the pass to get that extra edge. Windage has alot to do with it. Pretty stupid in a street car.
Old Nov 12, 2006 | 04:55 PM
cidgrad130's Avatar
Would you get even better mileage if you left out all the oil?
The engineers designed the acceptable level for a reason...best to stick with it and find you minimal mileage gains somewhere else (air filter/spark plugs/PCV/etc.)
Cheers!
Old Nov 12, 2006 | 06:15 PM
kablamo's Avatar
Less oil means less weight, so better acceleration too!
Also, consider using olive oil instead of mineral oil; it's lighter per volume, improving gains!
Actually, if your engine is running properly, whether you are at the top or bottom of the dipstick range, the engine will be able to maintain proper lubrication. The only thing is you will have less in the oil pan, meaning more risk of starving the engine. More risk, and no gain in efficiency, unless you think the possibility of metal on metal is worth saving literally pennies in gasoline.
Old Nov 12, 2006 | 07:06 PM
mgags7's Avatar
Stop with the BS
H22As have windage trays, that keeps the crank from blowing wind into the sump
If the oil is very very high, then the crank will have to slosh through it as it spins, that would cause parasitic loss, and less MPG
If your oil is at any normal level on the dipstick, you're fine, there is no difference as far as the engine's oiling system can see, just a few less lbs of oil, and a higher risk of running too low w/o realizing and seizing an engine.
The level of oil in the pan, unless it is below the pickup, which is nearly impossible, does not influence the oiling system. period.
Old Nov 12, 2006 | 07:18 PM
InitialJRift's Avatar
* B A N N E D *
Default Re: (bb4ever)
i've taken notice, that bb4ever is a ******* genius, seriously haha
Old Nov 12, 2006 | 07:32 PM
dek1mfk's Avatar
Default Re: (InitialJRift)
bb4ever FTW!!
Old Nov 12, 2006 | 09:02 PM
piggydog's Avatar
Default Re: (dek1mfk)
haha I'm talking about putting oil in between the 2 levels but leaving it on the lower side of acceptable. I'm not talking about draining all the oil.
Old Nov 12, 2006 | 09:11 PM
mgags7's Avatar
Did you not read my post?
