type r intake manifold
Old Nov 11, 2006 | 05:29 PM
rs_sexy's Avatar
Default type r intake manifold
will the type r intake manifold fit on an 02 rsx auto??? i kno wat everyone is gonna say but i just want to see how much i can get out of my auto. if the fit is possible will i have to do a couple of modifications?? thanks
Old Nov 11, 2006 | 05:44 PM
acura8851's Avatar
Default Re: type r intake manifold (rs_sexy)
yes it will work u need the itr intake manifold install Hondata IMG or the type S one and a type s throttle body ull be good to go it will be a little gain but ay its better than noting i guess lol
Old Nov 12, 2006 | 07:39 AM
jdmpwr07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rs_sexy &raquo;</TD></TR><TR><TD CLASS="quote">will the type r intake manifold fit on an 02 rsx auto??? i kno wat everyone is gonna say but i just want to see how much i can get out of my auto. if the fit is possible will i have to do a couple of modifications?? thanks</TD></TR></TABLE>
not worth it...you will spend a lot of $$$ and get little gains if any because you are disabling the secondary runners on the intake and your torque will drop drastically. that manifold was made for the base and unless you are doing some serious work its not worth it.
Old Nov 12, 2006 | 12:30 PM
rs_sexy's Avatar
Default Re: type r intake manifold (sleepin02rsx)
so basically wat i think your trying to say is just to stick w/the stock intake manifold?? i mean i am going to change the internals and everything only one step at a time cuz u kno money is the issue here, but what other intake manifolds are there for the base model that will give it more power??? any aftermarket ones?? thanks
Old Nov 12, 2006 | 12:46 PM
jdmpwr07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rs_sexy &raquo;</TD></TR><TR><TD CLASS="quote">so basically wat i think your trying to say is just to stick w/the stock intake manifold?? i mean i am going to change the internals and everything only one step at a time cuz u kno money is the issue here, but what other intake manifolds are there for the base model that will give it more power??? any aftermarket ones?? thanks</TD></TR></TABLE>
just go boost...if you really get into building you motor you could go with an k20a2 manifold but you'll need k-pro and a type s throttle body. but if i were you id either get a k20a2 swap or go turbo.
Old Nov 12, 2006 | 05:54 PM
rsxtacyy's Avatar
changing the intake manifold really isnt going to get you much gain no matter what manifold you put on it. the only way to make that worth it is to put a lot of money into your car in other mods. What you should do instead is start with exhaust and building the internals then get yourself a turbo kit or a nitrous kit. Then fuel system, etc.
Old Nov 12, 2006 | 06:36 PM
cnyej1's Avatar
Default Re: type r intake manifold (acurtayy)
That manifold is not worth it since you cant rev high enough for it to be of any use to the stock A3.
Old Nov 12, 2006 | 08:12 PM
rs_sexy's Avatar
Default Re: type r intake manifold (cnyej1)
its not stock though i got dcrh, v2 intake, and a 5 zigen catback but dont kno it does a good job with my friends i just need more but i wanna go na not turbo i just wanna see how much i can get out of it being na
Old Nov 12, 2006 | 09:26 PM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rs_sexy &raquo;</TD></TR><TR><TD CLASS="quote">its not stock though i got dcrh, v2 intake, and a 5 zigen catback but dont kno it does a good job with my friends i just need more but i wanna go na not turbo i just wanna see how much i can get out of it being na</TD></TR></TABLE>
Like I said: stock. You cant rev any higher with those mods can you? You dont have Kpro so your not going to see any gains with the manifold. You have no internals. Your valvetrain is stock etc no cams blah blah blah.....need I go on?
Old Nov 13, 2006 | 10:10 AM
rsxtacyy's Avatar
cny is right you wont see any benefits in upgrading your intake manifold when the mods you have dont need it. If anything do that last. Buy a k-pro upgrade the internals, cams, clutch, flywheel, etc. then you will benefit from an upgraded Intake manifold.
biggdogg
Sep 21, 2006 03:31 PM
NA.GEORGE
Dec 16, 2004 11:23 AM
nicksweetlude
Aug 11, 2002 01:03 AM
