Please help me find out what code(s) are being thrown (vid inside). Im having trouble
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote"> i counted 1 flash and then 16 .
i thought code 16 would be 1 long flash followed by 6 short flashes?</TD></TR></TABLE>
O yea your right.
I dont understand why there is 16 short in a row. That doesn't make sense.
O yea your right.
16 short flashes in a row is weird. sounds like it's time to try another ecu.
https://honda-tech.com/zerothread?id=468260
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">16 short flashes in a row is weird. sounds like it's time to try another ecu.
https://honda-tech.com/zerothread?id=468260 </TD></TR></TABLE>
If infact the ECU is bad. What causes it to do so? Just from being old, dirty, corroded, etc?
Yea it is code 16 and code 1. It's normal for you to have the 16 short flashes or at least in my experience my ecu did the same thing rather than a long and short.
Your ecu is fine.
Your ecu is fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peanut butter »</TD></TR><TR><TD CLASS="quote">Yea it is code 16 and code 1. It's normal for you to have the 16 short flashes or at least in my experience my ecu did the same thing rather than a long and short.
Your ecu is fine.</TD></TR></TABLE>
So when you fixed the problems the codes went away?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 »</TD></TR><TR><TD CLASS="quote">make sure your injector clips are fully seated right, how is the motor running?</TD></TR></TABLE>
It seems to be running fine. Although idle is a little funny at times.
MAD SCIENTIST
May 8, 2003 07:14 PM
