h22 swap axles??
i have an h22 91 accord lx right now.
this winter i plan on ditching the 2800 pounder and putting the H in an Eg coupe or possibly and Ek if i can find a shell cheap.
i can find mounts easy. the wiring shouldnt be a problem. shift cables shouldnt be too hard. my question is with the axles. can i use whats on the accord right now? my whole swap is from a 94 jdm prelude i was told. can i use any part of those axles? its the lsd tranny if that matters. i know hasport has axles for this swap but if i can use these then there's no point in buying them.
any info is helpful. i searched, didnt c what i needed.
thanks alot
thanks alot
You can use the stock midshaft but the axles are a hybrid combo, like H22 inner joints on B-series shafts/outer joints. You can buy them on Ebay for like $150 shipped with no exchange, so forget overpriced hasport.
the most common fix are 88-89 teg or 90-91 teg with Accord or lude inners. You CANNOT use the entire accord or lude axles if that's what you are asking. No need for fancy axles either. I used Advanced auto parts axles for 4 years and only had 1 snap on me. The 89 axles are 1/2-3/4" shorter than the 90-91 axles so like mentioned before it all depends on what length you need. 94+ teg axles are even longer though. HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">i needed a longer axle!
my passanger side kept popping out and leaking
whats axels are you using?
</TD></TR></TABLE>whats axels are you using?
-Bionic-
Aug 7, 2003 02:14 PM
MiniMeonBoost
Jun 4, 2003 06:17 AM
