sticky pkg brake when cold weather
Old Nov 11, 2006 | 01:51 PM
HondaHeddie's Avatar
Default sticky pkg brake when cold weather
I was driving xcountry recently and when going through -cold- areas (w/snow and such) the pkg brake will not disengage
after pulling the lever up then putting it back down the cable does not release
the lever is slack until 15-20 min during which time the cable slowly takes up the slack
I dont want to drive with the brake on, nor do I want the cables to disengage from the lever
is this a lube issue, or do I need to replace cables?
as mentioned in other threads I will be replacing the RTA's asap so the cables will be replaced with them so I understand.
can I lube the current cables?
Old Nov 11, 2006 | 01:53 PM
Jared's Avatar
replace the cables
Old Nov 11, 2006 | 02:38 PM
thesmogman's Avatar
Default Re: sticky pkg brake when cold weather (HondaHeddie)
You can try some silcone spray from both ends of the cable. WD-40 won't last long.
Also check to see if the cables are kinked and straighten them if kinked.
Old Nov 11, 2006 | 04:20 PM
sierrakilo's Avatar
Sounds like you have a break or some sort of damage in the outer jacket of the cable that allows moisture/water to get in and then freeze which cause the cables to stick. Check to see if you have anything chaffing/rubbing against the cables in the wheel well.
flyinfree
Sep 9, 2011 08:55 AM
imadigitalgod
Jan 5, 2010 01:23 PM
thebinaryman
Dec 4, 2007 05:23 PM
HondaHeddie
Feb 14, 2007 11:40 AM
MechEng
Dec 7, 2003 09:13 AM
