crx si clutch wont disengage Please help
Old Nov 11, 2006 | 01:17 PM
Yaa's Avatar
Yaa
Default crx si clutch wont disengage Please help
i just put a new tranny on and the clutch will not disengage and its a cable clutch and the cable is tight enough and every thing is lined up any ideas?
Thank you!
Old Nov 11, 2006 | 01:54 PM
Targa250R's Avatar
be professional
Default Re: crx si clutch wont disengage Please help (Yaa)
Is the release arm moving when you push in the pedal?
Old Nov 11, 2006 | 02:01 PM
Yaa's Avatar
Yaa
Default Re: crx si clutch wont disengage Please help (Targa250R)
only about a quater to half of the full arms movment
Old Nov 11, 2006 | 02:11 PM
e jay one's Avatar
did you rember to put that little bolt back in when you replaced the throw out bearing? did you adjust the clutch cable the right way?
Old Nov 11, 2006 | 02:13 PM
Yaa's Avatar
Yaa
Default Re: crx si clutch wont disengage Please help (e jay one)
This may sounds rather noobish for me but i never replaced any bearing and i never took any bolt out from the back of anything. please let me know if i should have and if possible directions on how to do it.
Old Nov 11, 2006 | 07:23 PM
Yaa's Avatar
Yaa
and yes clutch cable is set up fine
Old Nov 12, 2006 | 09:50 AM
e jay one's Avatar
who put the clutch in? when you replace a clutch its not just the clutch disc there is also a pressure plate, throw out bearing, and pilot bearing.
Old Nov 12, 2006 | 10:18 AM
Yaa's Avatar
Yaa
clutch wasnt replaced its still the stock clutch.
Old Nov 12, 2006 | 05:45 PM
Yaa's Avatar
Yaa
someone please help me out
75euRFE
Jul 11, 2011 10:30 AM
KillerHippy
10
Sep 27, 2010 11:26 AM
blackfrohatch
21
Jan 15, 2003 11:37 AM
