ctr or itr pistons in ls motor?
Old May 7, 2002 | 04:42 PM
unsurpassedLS's Avatar
Default ctr or itr pistons in ls motor?
i just put an ls in my eg hatchback. the rings were bad on the stock pistons -so i am trying to decide whether to use itr pistons or ctr pistons. will the ctr pistons be ok to run on without octane boost? -also , i know when attaching itr pistons to ls rods- you have to mill 1mm off each side of the rod. --do you have to do this when attaching ctr pistons also.-------oh and what do you think about b16 pistons?-they would raise my compression to 11;1.
10.8;1 for itr and 11.4;1 for ctr.
i want ctr's for highest compression , but i'm worried about running only on 91 octane because thats all california has to offer.
Old May 7, 2002 | 04:51 PM
qtiger's Avatar
Default Re: ctr or itr pistons in ls motor? (unsurpassedLS)
11.4 should be safe on 91.
Old May 7, 2002 | 05:07 PM
Default Re: ctr or itr pistons in ls motor? (qtiger)
that is what i thought , but i am hoping to find out from someone that has done this mod. thanks for your input. --how sure are you?
Old May 7, 2002 | 05:39 PM
dubster99's Avatar
You can go up to around 12:1 on pump gas
Old May 7, 2002 | 05:49 PM
Default Re: ctr or itr pistons in ls motor? (dubster99)
even with stock fuel injectors, regulator,etc..?
Old May 7, 2002 | 06:10 PM
Mike B's Avatar
CTR pistons on an ole friend of mine's LS, came out to be right over 12:1 compression.
Old May 7, 2002 | 06:34 PM
dubster99's Avatar
Default Re: ctr or itr pistons in ls motor? (Crazy Bovine)
According to all the CR calculators, with stock bore, stock head gasket, stock deck height, and no head milling, compression should be 11.40:1. With a b16 head it would be closer to 12:1, actually 11.97:1.
Old May 7, 2002 | 07:34 PM
yes, those were the calculations i got. And this hatch is for street use so i am not putting a vtec head on it. ---but what about the milling on the rods for clearance ?
i know the rods need to be milled for itr pistons , but what about ctr's?
GSR_hatch936
11
Jan 10, 2008 12:06 PM
CaseBone
32
Apr 3, 2007 05:15 AM
eddiecut
Feb 11, 2003 10:12 AM
B00ST2nR
Apr 28, 2002 10:58 PM
HKxGroggy
Oct 30, 2001 03:42 PM
